peter2772000
Hey guys, I've got a problem getting my VFD to run with my air compressor.
With a smaller drive pulley, it'll start and build up speed with no issues. Soft start of course, but the motor gets to it's 60Hz/3450 rpm without issue. Problem is, I'm only getting 830 rpm at the flywheel. To maximize compressor output, I need 950 rpm.
Originally (and because my original 3.25" adjustable pulley was closed up to the max), I simply bumped up the hertz to 70, which gave me exactly 958 rpm flywheel speed. Utopia, right?
Well, then I started thinking, never a good thing. Is it possible that running the motor to 70 hertz (which gave me a motor rpm of 4k rpm) would/could cause harmonic vibrations? It just felt that the motor was shaking a bit more than I thought it should. So I bumped up the drive pulley to 3.75, and that's when everything took a dump.
Simply put; The compressor never gets up to speed. Starts slowly and builds itself up head-pressure, which it then finds impossible to fight before getting up to speed, and stalls out. If I drain the tank completely of air-pressure, the compressor will start and get to the target compressor rpm, no problem. But if there's even just 10 psi in the tank, I end up with the same problem.
So unless someone else with VFD's can shed light on this problem, or I;
- A, go back to the smaller drive pulley and up the hertz back to 70
- B, install an unloader type solenoid on the discharge line of the compressor which would stay open for the first 10 seconds or so 'till the compressor was up to speed
I realize that simply putting on the smaller pulley would fix this. But it bothers me to have to run my motor at 70Hertz.
Now....... it's personal.....
