Jawn
Just got a new plasma cutter. Not a lot out there on this model, so I guess I'm taking a bit of a chance, but it's not the usual Chinese plasma cutter (it's Italian... fra-gee-lay!) and I got it for what I think is decent price (under 600).
https://www.ine.it/en/welding_detail/200/skyline-33-skyline-33-plasma-cutter
Since I don't have any prior plasma cutting experience, this is not presented as a review but more as general info since I found relatively little out there on these.
The basics:
230v only and comes with a NEMA 6-20 plug (US-style 20 amp)
10 to 33 amp output
Manufacturer claims up to 15mm cut in mild steel
Built in regulator/filter on the back, digital pressure readout on front panel.
Work clamp has what seems like good quality cable (10mm^2, or a bit bigger than #8) and a Dinse style connector.
Comes in a blow-mold case.
Split the case open, one compartment for the main unit, one for cables etc.
All spread out. Trafimet S45 torch, counting what's preinstalled it came with 2 electrodes and 3 nozzles. Enough to get me started. Operationally, a press of the knob will trigger air pressure readout on the front (in bar) and also turn on the air briefly so you can see what the pressure is as it flows and after it stops. Same knob also adjusts output power from 10 to 33 amps. Controls are large and can be operated with gloves.
Back of the unit shows the filter/regulator and 6-20 plug. Air inlet is a quick-connect 6mm OD tube (included) with a 6mm quick-connect to 1/4 NPT fitting (also included). Milton V plug shown was not included. Not shown, in an effort to keep debris and moisture out of the unit I put one of the disposable plastic spray gun filters inline.
1.25" by .25" angle... ignore the left leg of it, that was my amateur **** trying to get the hang of it. Clamped something on to act as a guide and my cut was much improved.
I guess I would do well to get or make some kind of standoff to keep the torch an appropriate distance from the work. That or get drag tips.
Not sure if INE has any kind of service center in the US or if broken units go back to Italy, but hopefully I won't have to find out.
The basics:
10 to 33 amp output
