vavet
I had an electrician wire in a 230V 30 amp circuit for my lift when he was wiring the garage. I’ve changed my mind about where I want it thought. My 100 amp sub panel has plenty of space, so I’ve decided to run new 10/2 romex from the panel on a new breaker to the other side of the garage. Now I have an extra circuit that is simply terminated in a junction box with a blank cover plate.
What would be the best way to handle this? I plan to have the garage insulated and dry walled in the next year. I was thinking of adding a receptacle to this box so I could use it for whatever comes along- a bigger compressor, welder, etc.
Do these larger pieces of equipment typically require hardwiring inside the JB or can I install a plug? What type of plug? Twist lock or straight blade? The upside of using a plug and receptacle instead of hardwiring allows me some flexibility. What are the downsides of using a plug and receptacle?
