Recommend a Filter/Regulator/Lubricator?
Jetpilot718
grumpychevy
Indiana
I’ve used Parker brand at work and have had no issues at all with them. You can purchase them individually or as pre-made units. I’ve used them both ways.
larry_g
oregon
99% of the members here do not need a lubricator. Lubricators are to be installed on the input of a machine, or within the machine itself. What machine are you installing this on?
lg
no neat sig line
J
Jetpilot718
lg
no neat sig line
There will be one F/R/L per BENDPAK four post lift. I'm planning on two lifts for my garage. I'll probably mount the system on one of the legs, as for whatever reason the mfgr. is adamant about the use of these otherwise warranty is void.
larry_g
oregon
Alrighty then, the first time I remember a member has wanted one for the correct use. As said Parker, Wilkerson, or Norgren all good units. Good luck.
On edit; All the machines that I have worked on with an oiler on the input also have the exhaust ports plumbed to a coalescing filter to keep oil atomized air from being returned to the local atmosphere. Something to think about if you want to keep your shop clean and healthy.
lg
no neat sig line
mlabouff
I just installed a Bendpak HD9XL and a pair of RJ45LP bridge jacks. The lift installation manual does not mention the need for an FRL/Oiler and in fact the RJ45LP manual has a diagram that specifically calls for non-lubricated air. Anyone know when this changed? Was going to install an FRL, but don't want to lubricate the air if not required. Will just go with a filter and regulator otherwise.
Sumboodie
AK
