zeekh
Anyone else getting this error on Lowes?
An error (400 Bad Request) has occurred in response to this request.
I was getting it a ton yesterday, but never had before.
Also tried getting the Google Mini + outlet deal, but wouldn't take off the plug cost. Worked earlier in the day, but not at 11pm, even though it still listed the promo. Hoping they will hobor over the phone
I know "hobor" must be a typo for something along the lines of 'adjust', but I can't figure out what exactly, lol.![]()
I haven't had an error like that on the Lowe's site before either.
Always. Just refresh. Lowes website has lots of errors in my experience.
I've had a issues with checking in or checking other stores with the Lowe's site
New lower price ( in my AO ) though so no deep discounts in the future
Found this deal at my local Lowes (72761). Portamate Wood Rack item # 752430 for $19.98 was $59.98 a few weeks ago. It was located in the area with the garage organizing items.
Lately there's been an issue with in-stock items not showing up on their website when you type in the item number or do a search. It's also the time of year they do the inventory cycle count, so a lot of numbers are off.
Local store still has their light bulbs on clearance, they had a ton of T8 fluorescent bulbs as well.
Picked up an 8 pack of Daylight bulbs for $9.40. I use them in the kitchen.
Washington, MOThat will also prevent people from doing nationwide searches on sites that share deals for $.
Washington, MO
Everyone should use BrickSeek. How else would I have found this?
Question for lowes and brickseek users.
Do you manually lookup the item# on lowes.com first to get the product# in the url to input on brickseek? Or can brickseek use the item number directly somehow?
My apologies, not discount related although it might help others as-well.
Have they not clearanced out winter supplies yet?
Seems like Lowes put snow shovels, gloves and ice scrapers on clearance in February last year.
While I was on the phone ordering today, I asked the girl about the product not coming up in the results based off item #. Of course the item # i gave did not have that problem today.
When I worked retail, inventory cycle counts were to correct the 'off' numbers. Unless you are conveying they haven't started inventory yet, and the numbers are more likely to be off. All all large box retail do inventory through out the year (minus Nov-Jan usually), as there would never be enough labor to do it all at the relative same time.
Lowes has a daily system called IRP - inventory replenishment program. The opening managers will go around and scan all empty locations. The morning workers have to find the items and fill the shelf, and select Yes or No on their store iPod. If an item comes up "no" too many times, the count will be adjusted and the losses are billed out.
This only helps to correct items of which there are zero. If there are 15 of an item and 5 were stolen unbeknownst to employees, the system will still say 15 instead of 10. After 8 are purchased, the system will say 7 even though there are only 2. The issue may not be noticed until it reaches 0.
Every so often, usually at the service managers' discretion, smaller cycle counts will be used to keep track of high price or theft-prone items, like GFCI breakers or certain tools. The employees go through the shelf and top stock and count the items, and the system count is adjusted.
Once every spring, Lowes has a third-party group come in and do a full inventory of the entire store. About 20-30 people show up in a bus or a couple vans, go through the departments very quickly, counting each item at each location. This inventory count relies on the store employees having already put the correct items in the correct places. If there is 80 grit sandpaper behind 40 grit sheets, they'll be counted as 40-grit or whatever is supposed to be there.
Another tip for clearance deal hunters: some items will continue to drop in price until the count reaches zero, but if the count was off to begin with the price will go back up to normal price once the count hits zero. If there's 15 items but the computer says 10, once 10 are sold the price for the 5 remaining will jump back up to normal price. The managers have to re-adjust the count at this point for clearance prices to take effect again, and it often goes unnoticed.
snipped: Lowes inventory craziness
That's why we recommend AGAINST using Brickseek.
In my view, Lowes and HD have taken opposite positions on inventory management and clearance:
Lowes: low-labor inventory system. Clearance items are rarely gathered or actively cleared out. Many clearance items are hidden and unmarked. This results in clearance items being sold at lower prices with many markdowns. Maximum possible discount can be over 95% off retail. This system probably costs the store very little, and they get very less from clearance sales.
HD: high-labor inventory system. Clearance items are constantly gathered and actively cleared out. Most clearance items are end-capped and individually marked. This results in clearance items being sold at higher prices with fewer markdowns. Maximum possible discount is about 75% off (excluding pennies). This system costs the store more, but they get more money from clearance sales.
IMHO, Lowes' approach is better for bargain hunting. If you hunt pennies, then maybe it is a different story.
Be aware that Brickseek tracks what people search and sells that information via memberships. If you use Brickseek, you are essentially giving the competition, resellers, etc. the details on the bargains before us users even know about it.
Understood, I won't post anymore deals found through Brickseek.
It is an employee not managers that do that mon thru thur. They are doing complete inventory this week.Lowes has a daily system called IRP - inventory replenishment program. The opening managers will go around and scan all empty locations. The morning workers have to find the items and fill the shelf, and select Yes or No on their store iPod. If an item comes up "no" too many times, the count will be adjusted and the losses are billed out.
