Greatwhitewing
- Joined
- Nov 20, 2011
- Messages
- 531
Can I run multiple boards through either simultaneously or with staggered time intervals (10 seconds'ish)? These will be 8 foot long and someone at the back end catching and stacking.
I need to run through about 75 kiln dried 2x3x8' pine studs down to 1-1/4x2-1/4 with at least 4 passes for each board could be very time consuming one board at a time. The calculated 9 hours could be reduced to about 2-3 hours with several boards going through simultaneously.
Would the max bite I can take be reduced using almost the full blade width?
I don't require super fine finish, used a table saw in times past for similar projects and was good enough.
Interested in experiences or advice. Yea or nay?
