Some more inside pictures. This shows the lift room as it was being reborn so to speak. It was the most puzzling room since it had many different angles and roof lines I had to tie together. Wasn't really sure how it would turn out. The shop always had bare block walls inside and almost no heat. Certainly no insulation of any sort, a total loss system for sure.
Those shelves contained many NOS parts.
This is the same corner after it was emptied out. Notice how welding smoke has blackened the interior wood? I removed one of the doors that was in this room. You can see behind the ladder on the left the slightly different concrete block in the shape of a door. I found some blocks around the property and guessed they were left over from the time this room was enclosed. They matched pretty closely on the outside, the inside was covered up. The yellow line near the ceiling was the gas line. Each room has it's own furnace, hung from the ceiling so they don't take up floor space. and it's own thermostat which allows me to zone heat. You can also see one of the lift ramps on the floor, not painted yet.
Same corner months later.
Here you can see the roof of the original shop and how the lift room roof was grafted to it. Since I was insulating and heating this space I had to build a stub wall over this space. That's the stub wall that eventfully I hung the restored sign from. You can also see that I'm beefing up the overhead wood beam they used to pull engines with. On the floor note the lift ramps and lift control cabinet.
That's the lift in the foreground in the "up" position, stub walls all done and insulated.
I know you've seen this picture before but this is nice to see it with the one above it, taken a few weeks before while being built.
And this is how it turned out. The ceiling space is pretty busy with a lot going on up there. The overhead oak beam is from the same batch of oak that I used to frame the windows, doorways and base trim. Same stain and finish so it all ties together. It's goofy I know but that beam has 5 coats of finish, sanded between each one. It's as smooth as a baby's....
I knew it would be a focal point so I wanted it to look good. Yup, I over did it, but I like it and I like looking at it! The beam extends to the side load bearing walls and is fully functional if you ever wanted to use it to pull an engine, no worries! The incandescent light fixtures you see are used throughout the shop so if you come in at night and just need to pick something up you don't need to fire up the florescent lights.
Reverse angle. Room from the other end. The blue line on the wall is my powder coated aluminum airline. Made in Germany, uses compression fittings so there is no air loss past them. The air line drops take air from the top of the horizontal line. That way any moisture in the line doesn't travel down it to your air tool. There's a drain at the end of each branch of line. Really a neat product. If you look closely at the lift control cabinet, you can see a seem across the top. That's where the backside reservoir meets the front half housing the pump and motor. Note the oak around the windows and door. This room is easily my favorite. It's visually very interesting to me.
I'll have more later. Thank you to everyone for your input. Sharing is what this is all about isn't it? As for questions, I will answer them, promise!
Thomas
