Here you go
Cool, thanks!
I got tired of my side shelf of my tool cart dropping when bumped today and came up with a super easy solution that only takes a few seconds using a magnet that will keep it from ever dropping again.
Here is a 2 minute video that shows what I did.
Hope this is helpful for others! Chris
Does the 5 drawer cart detach from the rest of it so you could use it as a top chest for example? I ask because I’m looking for something to put in the bottom section of my bluepoint cart.
Also does someone have the dimensions of the 5 drawer section of the cart?
People on this thread have combined 2 four drawer carts like that, don't remember seeing the 5 drawer ones done like that.
Man, the auto log out time for this forum is SHORT. I typed up a nice post only to lose it when I clicked "Preview Post".
As previously mentioned...I turned my 4 drawer cart into a drill press and grinder cart. I finally got the pictures off my phone and figured out how to attach them to show what I've done. The first two pictures are upside down. They are correct on my phone, on my computer, and I even tried opening them and rotating the around 360 before closing again. I have NO clue why they loaded upside down.
I use the drawers to store my socket set and wrenches. My flux core welder squeezes in the lower tray to add some extra weight down low. Stability is very good and I rarely move it out around. With the drawer lock disabled, one drawer liked to pop open too easily but after slightly squeezing the back of the slide that goes over the rubber bumper on the stationary part of the slide, it now stays closed.
To build the top I first removed the metal top and hinges. I didn't have any plans, just a rough idea of what I wanted. I used plywood scraps left over from building my kitchen cabinets. There are four longer carriage bolts in the corners to secure the frame plus the back frame piece sits on the metal around the lock buttons and there is another vertical plywood piece in the middle of the front frame piece for support. The lock buttons are depressed. The plywood grid was glued together to help support the plywood top from sagging under the drill press weight. Two full extension slides on the left side allow the grinder top section to move over to access the storage area. It's now a slightly taller area but also harder to access stuff under the right side. I keep old bits and rarely used accessories under the drill press.
Not pictured is a double sash window lock to keep the sliding grinder top secure. My brother got his knuckle caught in a grinder back in high school so I definitely didn't want to risk that section opening by itself. The grinder sits on oak dowels in case the drill press table needs to be lowered to accommodate thick, longer wood pieces. Also not shown is the 1/16" thick Maple edge that I glued on to hide the raw edges of the plywood top.
Looking back at the pictures I realize 14 months have passed since I built this. It still works/slides great. I have since enclosed the main workbench with plywood building five large drawers under the vice. Then I built doors (one long door folds in back upon itself) to enclose the right side and L-shape part that you can't see. My next garage project is to have a sub panel installed, rewire the garage, install insulation, and finally put up plywood, OSB, or drywall on the walls and ceiling. Then I'll be able to work further into the winter and be more comfortable during Summer. I need to tackle my last large home project and build a bathroom vanity as I remodel the upper bathroom.
A couple of questions. First how did you attach the cans to the shelf? Second, where can I find that make/model shelf? Those are some nifty mods you've done. I hope to use some of them in the future.Here are the pics of my cart. The fork cans are attached to the shelf, the impacts are in them .
If you are talking about the can shelf on the 5 drawer tool cart they come with it and is is attached to the support that also holds the drawers. 2nd the shelf is sold as a separate accessory by harbor freight.A couple of questions. First how did you attach the cans to the shelf? Second, where can I find that make/model shelf? Those are some nifty mods you've done. I hope to use some of them in the future.
Sent from my Pixel XL using Tapatalk
I'm talking about the tubes underneath the shelf that hold your drills. I believe that you referred to them as "fork cans".If you are talking about the can shelf on the 5 drawer tool cart they come with it and is is attached to the support that also holds the drawers. 2nd the shelf is sold as a separate accessory by harbor freight.
That’s awesome and want one. Getting my first 5 drawer on Friday with the $150 sale. Wonder how easy it is to make something like that with a second one.
I wanted red and black so I put mine together from the red cart and new black tool cart.
IIRC, there was a bit of fabrication and lots of tinkering involved to get the small drawers in.
It wasn't a straight mashup.
Does this mean that you also have a spare black and red cart hiding in the corner ?![]()
Blue and black and a full 90 degree lift in the lids. Might someone in HF's backroom been lurking on GJ?
Someday they may even offer all their chests and carts in the blue and black colors. And lets not forget the side shelves and matching colored towel holder and misc. accessories shelves.
One could hope.
It helps a lot. I appreciate your detailed response. Thanks.The big shelf is craftsman, I was walking through Sears one day and found it on clearance for $10. Here is a link to the shelf: https://www.craftsman.com/products/craftsman-plastic-side-shelf?taxon_id=2240
Attached to it is a metal Kobalt magnetic tray. I took the magnets off and attached it with a couple of bolts. Inside the tray is just a box made out of 1/4" plywood and painted with hi-temp grill paint (It dries flat black and seems to be pretty tough). I have made a bunch of these boxes of different shapes and sizes to organize my cart...I am a bit OCD when it comes to organization. Here is a link to the tray, which they evidently don't sell online anymore, but I am sure you can find something similar on amazon: https://www.lowes.com/pd/Kobalt-Magnetic-Tool-Tray/3076269
On the bottom of Kobalt tray I cut and attached three "fork cans" I riveted them to the bottom of the tray and riveted them to each other to make them a little more sturdy. I work for a Harley Davidson dealership and we go through a ton of these things. They are a stock part that comes on the front of Harley's above the fork sliders. Mine are stock ones that I modified and painted. Here is a link to the parts that I am talking about: https://www.denniskirk.com/509209.s...p7ACh3xiAdlEAQYAiABEgKE6vD_BwE&ad=45713335117
Hope this helps!
Welcome Two_car_garage. Be careful lurking. It's addictive...pretty soon you will find way more information and then start dreaming up new ways to improve your work space(s) and then you start looking for stuff to buy and collect and restore and it's super fun!
Take a few minutes to flesh out your member profile and tell us a bit more yourself.
Sent from my SCH-I545 using Tapatalk
Hope this helps!
They work good but are very pricey. I use pieces of pvc for my cordless guns. It's strong and very cheap to buy
here's one in my toolbox of my truck
Larry, it depends on the tool. I use 3" PVC for the small 12v impacts and drills. These are Craftsman Nextec 1/4" hex impact driver and 3/8" Drill.What size PVC?
What part # from HF is the bottom box?
Thanks for the info. I'm thinking of attaching my drill and impact driver to the side of my 5-drawer HF cart with maybe some DIY version of this. I want the them parallel to the cart vs. perpendicular.
I'm not sure about the 5-drawer cart, but for the 4-drawer Home Depot and Lowes sell 16x16" pieces of plastic or metal pegboard that fit perfectly in the sides. I used to hang my drills on power tool pegboard hooks on there while I had the cart at work.
