Flarring tool kit, buy the single or double ??
cvcman
Syracuse NY
I needed to flare a pc of tube today and yup, no flare tool,,,so I see the kits, one does double flares the other single...
So can I do a single with the double kit ? Or do I need to have both or ??
texasprd
San Antonio, TX
It depends on what you are working on. If automotive brakes, you MUST do double-flare. I believe most other automotive applications (i.e. fuel lines, transmission-cooler lines) are double-flare as well - at least, that's how the pre-flared tubing is sold. Every fuel line and trans-cooler line that I recall R&Ring looked like it was double-flared.
gearhead1
NC
+1, must be double if you’re doing brakes......
ndnchf
Fredericksburg, Virginia
Do yourself a big favor and skip the cheap clamping bar type double flaring tools. I've had one for 15 years and it will work. But it is very difficult to get a perfect flare with them. It will often be off set to one side. That it's because those tools have no method of keeping the flaring point and mandrel perfectly even and concentric. You have to align everything perfectly by eye. I have gotten good flares, but also got a lot off less than perfect flares. To have leak free brake lines, it needs to seal perfectly.
Not long ago I came upon a much better tool for just a little more money. It is made by Cal-van tools. It uses a threaded adapter that holds everything perfectly concentric. The result is perfect flares every time. Google it to find videos on using it. They sell a number of different kits. I got the fairly basic kit for around $40. I ordered it through Walmart online and got free shipping too. Believe me, it's a big improvement over the old clamping bar tool.
^ valid points.
if you want to go cheap, you can pick up used old-school single flaring tools (just the clamp bar and the cone-shaped press thingie) for $10 bucks and up on Ebay all day long - just a matter of picking through listings.
there are usually several old-school double-flare kits listed as well, often missing one or two of the little widgets you need to do the double flare.
unless I'm mistaken, you can get those little widgets individually from Snap-on. (I could be dead wrong on that one.)
from the comments on this site, the guys who are earning paychecks by standing under cars on lifts all day don't have high opinions of the old-school flaring tools.
I've only had to flare copper tubing a couple times during my entire life (single flares) and it took me a couple tries to get it right.
YMMV
old__man
Gander, Canada
There is also something called an ISO flare. The project I am currently working on has these on the brakes and fuel lines. The also go by the name of European, DIN, and bubble.
ineedtools
SouthWest Florida
∆ this! You almost have to a complete idiot to NOT make a perfect double flare every time. It's one of be those tools that once you've used it you'll wonder how be you've lived without it.
Sent from my R1 HD using Tapatalk
engineer2
Chicago burbs
But I ASSume you can't do a double flare with a single tool.. so if I'm going to buy a kit buy the double flare kit
Yes. the double flare tool has "buttons" to create the double flare. To do a single flare, you don't use the buttons.
bczygan
DETROIT! Arsenal of Scrappers
I just picked up the 165 kit which is the biggest non-hydraulic kit they offer. Cheapest here:
http://www.tooldiscounter.com/default.cfm?nav=inc/search_return.cfm
$40.60 plus $7.95 shipping.
Cal Van 165 - Master Inline Flaring Tool Kit
features:
unique design lock the adapters, cone and tube in a perfect line making perfect factory flares every time with less risk of breaking adapters
clamp and set screws put pressure directly over the tube greatly reducing the chance of the tube slipping from the clamp
increases the overall life of the clamp by not wearing down the teeth inside from repeated slipping
low profile design allows the user to make flares on the vehicle and in tight spaces
flares can be achieved along frame rails or areas on the engine compartment saving time from having to remove components or complete lines to make repairs
includes:
3/16, 1/4, 5/16 and 3/8 inch double/single flares
4.75, 6 and 8mm double, bubble and single flares
Bill
engineer2
Chicago burbs
The only problem I've ever had was making a nice double flare and then seeing the flare nut still sitting on the bench.:lol_hitti
ndnchf
akalian
St. George Utah
It's true that often times the wing nut type flaring tool will allow the tubing to slip when you are making flares.
But I've found if you take a C-Clamp and clamp the bars close to where the tubing is being flared, it eliminates that problem. It doesn't have to be a big one either, a small 3" or 4" one works well. If you have room, clamp both sides.
Only downside is that if you are trying to do this on the car with limited access.
6PTsocket
On a related matter, a double flaring tool will make a passable bubble flare if you only go part way with the second flare.... and remember to install the flare nut. LOL!!
I did this until I bought a bubble flaring tool and frankly the results don't look much different.
JUNK-MAN
PA
Buy a double flare kit, you can do single and double with it and as preiviosly said you can also make a decent bubble flare.
kctyphoon
Jersey/Staten Island
Just watched a demo on that cal-van kit.. wish I knew about that when I I was making new brake lines for my truck.. those wing nut kits are useable but are far from what you'd want for a result.
Caligula455
I’ve had awesome results with a Mastercool hand held hydraulic flare set. It does single and double flare as well as bubble. It was pricey but it’s so easy it’s fun and the result for me have always been perfect.
Except when I forget to put the flare nut on first ...
theoldwizard1
SE MI
I have the Eastwood tool and it rules! Also does the single bubble flares. You can add the 37° single flare dies if you need separately or they also sell the kit with both 45° double and 37° single.
https://www.eastwood.com/professional-brake-tubing-flaring-tool.html
Probably the best tool on the market ! $$$
A good runner up !
If you are ONLY doing brake lines this new style has gotten a lot of good reviews.
Eastwood "on car" Flaring Tool
