$5 DIY internal bead forming tool for small tubing
crashbumper
Gilbert, AZ
This isn't my picture, I found it while searching for internal bead forming tools. I went and bought the HF cutter mentioned below but I have not made mandrels yet.
I think I found this on an aircraft forum; a member made this tool from a $5 HF pipe cutter to form internal beads on small diameter tubing. This is the only picture, but it should be self explanatory. The other one he was building (underneath) didn't work very well, but he said the pipe cutter model worked great.
The cutter info:
HF #40913
$4.99
It's actually very similar to a tool made by Graham ($149.95).
Just wanted to get this info up here in case anyone can make use of it.
:thumbup:
gkring
Keller, Texas
How do you make the mandrels?
I have been using the mastercool flaring tool to make push to connect flares that work the same as rolling a bead. this looks to be a slick idea, but making the mandrels may involve some fancy tools of their own?
rylon
Beaverton Oregon
I have acess to a lathe and nothing to make at the moment, if you have dimensions I might be able to make some mandrels for you for the cost of materials and shipping,given that they can be mild steel. I can't do the welding though so that may affect your decision.
Rylon
C
crashbumper
Gilbert, AZ
Rylon
Rylon,
I will get you dimensions tonight. Welding I can handle, I just don't have access to a lathe.
rylon
Beaverton Oregon
We'll have to see how it goes on the lathe, and if everyone can use the same dimensions, that way I don't have to make multiple tools.
Rylon
grego
Sac, CA
I have a lathe also, can I get the dimensions to see if I can make up some mandrels?
C
crashbumper
Gilbert, AZ
Sorry for the delay guys; was sick since last Wednesday so I didn't get into the garage. I'll do my best to get these tomorrow!
lilredex
Toronto
Why not just use your flaring tool (with the double flare button) and put a "bulb" on the end of the tubing? Been doing this one forever, same result, no?
fordcragar
Yakima Wa.
What's the smallest tube size that anyone has made a mandrel to fit? It seems to me that 1/4" I.D. tube would be about the smallest that you could do.
NASTYZEN
St-Colomban,Que. Canada
If your going to invest time in making one of these. Start by finding small bearings and then design from there.
Mine has no bearings and is limited. Next one I make is going to have bearings for sure.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Crashbumper.
Thanks a million, I made a test with some basic mods on a pipe cutter and it worked great on copper pipes. :beer:
Will proceed to make a real tool based on the same principle.
Best regards
Ola
jpsgarage
I took the above idea and made one of these using an old tubing cutter. I did cave man the process a bit as I don't have a lathe, but do have a welder.
The grooves in the wheels were cut with a Dremmel too then cleaned up with a small round file. (I was careful not to cut too deep)
The round file cleaned up the grooves and gave them the right shape. 20240126_093517.jpg
The cutting wheel through bolt was very small, so I drilled and tapped a 6mmx1 hole where that was. (Can be any size in that range)
3 washers were used to offset a small 1/8 plate so it was 90 degrees to the wheels. (Close to 90, anyway)
Then I found a vw valve cover bolt that had just the right shape to it.
I cut the head off it and screwed it into a nut (6mmx1, but you can use anything) that I welded to the 1/8 plate. You can see that at the top of the first pic.
I needed to put a bead around a small 1/2" cooler pipe made of soft material. The first test went okay but I needed to smooth out the wheel grooves more.
Second test went well. Greasing up the pipe worked wonders.
Here it is all together
It works better than expected. This won't do very large pipe, but it is adjustable.
Hope this helps someone out there!
Jp
