Is that socket moving? Follow the line...
Knotgoalie
Ontario, Canada
This may be an old idea guys but a new one in my head. There are those times when using an impact wrench that it is hard to determine if the black impact sockets are actually moving like when removing a really tough bolt in low light or using a little finesse when installing a fastener so as not to cause damage.
Armed with a small set of impact sockets, and a white paint pen, I drew a straight line on each one every 90deg.
No problem now to determine visually just when that fastener is about to break loose or snug up...follow the white line! I have never seen sockets marked as such by either manufacturer or user but the trick works for me! I do believe I will heretofore name them "Zebra" sockets:cool::thumbup:
jsaw
Geneva, N.Y.
Thats an Idea. It also makes the socket more visible if you drop it, and makes it easier to identify it as yours. You could also use different colors for identification.
Usually, I watch the hole for the detent, Some of My sockets have the detent hole on 2 opposite sides
ddawg16
S. California
Eloquent simplicity......love it
About the only improvement I could suggest....sandblast the line. Make a template with a narrow notch.....use a fine medium blasting material....make line.
If you want to be really fancy....add your name or some ID # to the template just in case someone steals them
toolenthusiast
I use a paint pen to write the sizes on impact sockets. This will also let you see when they're turning.
K
Knotgoalie
Ontario, Canada
The more I think about this, the more I like it. It's one of those "Damn, why didn't I ever think of this?" things... in fact, it's fodder for the "thread of awesome" file...
Hope you don't mind but I'm gonna steal your idea. :D
You didn't think of it for the same reason I didn't think of things you came up with...you ain't me and vice versa!:D
Steal away...pics or it never happened:beer:
Mohawk Dave
SoCal
I got a full set of Snappy 1/2" impact universals from Jeepinz, and they have the sizes written huge on them in yellow paint marker. At first I was thinking I did not like it but after using them I love it and have continued to do that on other impact sockets.
