HD Drawer Slides
karoc
Hemphill Tx
Guys where can a person find full extension heavy duty drawer slides for metal drawers or tool cabinet?Looking for some that has a weight rating such as 150lbs.Thanks guys
chaosracing
Kutztown, Pa
You can use the off the shelf cabinet drawer slides HD and Lowes sells.They have some pretty robust ones for not alot of money. You can rivet or bolt them onto your metal drawers. Use self tapping screws into the cabinet. If you look at what majority or tool cabinet makers do today is rivet them on.
K
karoc
Hemphill Tx
Thanks guys,the 150lb rating is the minimum since the slides are made of thick material.The drawer will have just about that much weight on it,I don't want it to rack any while trying to push it in.Here's couple pics,the lathe cabinet is upside down but the smaller side cabinet is where I want to put the drawer.Down at the bottom will weld in couple brackets to mount the slides on then make just C channel drawer frame then build the rack on top of the drawer all mig together.
Iroc-Z
New Germany, MN
Not sure what your project is but these were built with Menards 100 lbs drawer slides. Holding up well.
K
karoc
Hemphill Tx
Thanks Flail I like that ideal,maybe purchase couple sets of 100lb capacity slides.Thanks for the links guys that is a big help,never though about Amazon
