Porcelain Floor-tile requirements??
mandylidel
After feeling like I was committed to acid staining my garage floor I think I have officially fallen in love with the idea of tiling the garage. The longevity of the flooring and the style are exactly what I am looking for. It had never occurred to me you could tile a garage!
So, off I went to look for tile and I found this at my local Lowe's. It doesn't have a PEI rating, but the break strength is higher than most tile I've been looking at. Do you think this tile would work in a garage application?
https://www.lowes.com/pd/Anatolia-T...n-x-36-in-Actual-5-9-in-x-35-43-in/1000274189
Angelfire
New Mexico and Ireland
I don’t see a COF rating (coefficient of friction) but guessing it is relatively good if it’s textured. It’s also probably not through body. Not a show stopper but understand that if you do get a chip in it, it will show.
Personally I’ve never worked with the plank porcelain before. I’ve heard stories of it being relatively bowed which could make install a bit more challenging. So that would be another thing to look at in person.
In saying all this, even more important than the tile itself is the install. Full coverage under the tile is essential or you risk breakage. A whole lot of information here on the board to walk anyone through the process and some darned good tiler’s that graciously share their knowledge.
Cheers
Bob P1
Greenwich, NY
Well, depends on if this is a storage only for cars garage or a "working" garage? I don't think a tile floor would be durable enough for even moderate work.
Angelfire
Please read up on the many threads from some very much working garages with tile installed. It's been used in working garages with great success. This isn't your typical track home tile install.
Edit: Here's but one thread.....also do a search for Jack Olsen beating his ceramic floor up with a 5lb hammer with no ill effect on the tile. https://www.garagejournal.com/forum/showthread.php?t=305707
Shea
California
These two links will answer a lot of questions and explain why porcelain works well on a garage floor. As mentioned above, one even includes the video of Jack Olsen beating on his tile with a sledge hammer.
http://allgaragefloors.com/porcelain-tile-garage-floor/
http://allgaragefloors.com/porcelain-garage-floor-questions/
I'm not so sure this is what you want. It's advertised as a floor and wall tile. I suspect that it has a PEI rating of 3 which would not be recommended for a garage. Also, plank tile such as this is harder to lay unless you are fairly experienced. As was mentioned, it does tend to bow a little. I believe that you don't want anything greater than a 33% overlap when putting plank tile down. The best thing you can do is contact the manufacturer and get the specs directly from them. Here is the link below:
http://www.anatoliatile.com/
mandylidel
Does this tile seem to meet more of the requirements you suggest?
https://www.homedepot.com/p/MARAZZI...Tile-15-60-sq-ft-case-SL021224HD1PR/205889877
I like the look of the larger tile 12x24, but do you recommend using 12 x 12 for better ease of installation?
Shea
California
This particular tile has a PEI or "class" rating of 4 which is good for a garage floor. The larger tiles are bit more difficult to work with because of their size, but as long as you back butter the tile and use a 1/2"x1/2" notched trowel you will be good. One of the benefits of the larger tile is less grout lines.
mandylidel
Shea, I think you are going to be my new best friend as I prepare for this project. :) (whether you like it or not! ha)
Has anyone tried to put infloor heat under these tiles? We are planning on putting a proper heater in our garage, but thought maybe some in floor heat would be nice especially the walkways in the winter. Thoughts?
deezee
Saskatchewan
I've got infloor heat under mine with no issues. My local tile store told me not to have it heating while installing as the mortar won't cure properly.
mandylidel
What type of in floor heat did you use? Do you remember roughly what the cost was for installing?
thanks!
deezee
Saskatchewan
My infloor heat project was done about a decade ago. I laid the tubing and had a plumber install a water heater converted to a boiler. (not allowed anymore) I"ll dread the day when I will have to replace that. I do not remember the cost. Sorry.
