Large 1/2" Drive Sockets
bpankratz
Hi, I am having a hard time finding a large 1/2" drive socket set. I need sizes in 1 1/4" and up, and 30mm and up. I would like to stay away from 3/4" drive if possible as these are not extreme torque and I don't want to have to buy a 3/4" ratchet and accessories or use an adapter. I will if I have to but would like to stay away.
I would also like to stay away from truck brands, as they are just too much to pay for a socket like that.
Your help is appreciated as always!
Finky198
North East
I know My snap on 1/2 chromes stop at 32mm that’s the biggest they offer.
My sae stops at 1-7/16” but I’m pretty sure those go higher. I have 3/4” drive stuff...for that
I think your best bet is looking for axle nut sockets or impacts...
patchap
Look for axle nut sockets. Should be able to get impact up to 35mm or so in 1/2 drive. I'm in Canada but I can get them for 10-15 each new
bpankratz
Sorry I should have said I am most likely looking for impacts, as all my 1/2" drive stuff is impact already.
davethorik
Norka, Ohio
My largest 1/2 drive socket is a Performance Tool (Taiwan) 36mm 6 point deep. I bought it years ago at Carquest for the crank bolt on my old Honda Accord.
unslow1
Illinois
I would bet you would spend a lot less buying a 3/4 set with a ratchet. I have many 1/2 drive large sockets and they are pricey. Most of my large sockets are Stanley, Wright and SK.
Lassen Forge
Granger has them to a buck 9/16ths... hold on to your wallet. Thing is once you're into the "plus" sizes you're putting a lot of stress on a 1/2" drive, and if you REALLY want to stick to a 1/2" drive system you need a 1/2 to 3/4 (or 1") adapter...
But even our lugnut sockets on our trucks at work are 3/4" drive...
ssdave
Eastern Oregon
My Proto and Snap-on SAE both go to 1 1/2", but I think the metric only go to 32 or 34. I have 3/4" drive above that, up to 55mm and 2 5/8", all in Proto. Most brands stop at 1 1/4" for 1/2" drive.
Realistically, usually you need more strength and leverage than 1/2" drive gives above about 1 1/8" anyway.
DFB
Southern VT/Western Mass
My impact set tops out 1 1/14" deep or shallow and 30mm so I have like 7 deep impact I bought as separate pieces over the years, all MIT (old Tekton) or Calhawk 32,34, 36, 38, and 1-5/16", 1- 7/16", and 1-1/2" the average price about was $10 a socket.
Now a days the axle sets HF and other names all sell are very similar and only around $40...is the way to go IMO.
For shallows and if on budget I would second the suggestion of a 3/4 drive set of import sockets in whatever class you need metric or SAE.
bob15
Northeasten, CT
Snap on, Proto, SK, Wright and even old Bonney's go to 1.5" in impact. You might be best served buy a set up to 1.25" and getting the larger sockets separately.
mrborohachi
Berdoo Route 66
problem solved for going from 1/2" dr to 3/4"
https://www.tooltopia.com/grey-pneu...MI9Jnl2rPv2QIVFZJ-Ch2TvgP2EAQYAiABEgLkvfD_BwE
Tallpilot
Orlando
Sunex, Grey Pnumatic axle nut sets or Tekton has singles up to 38mm and a nice set of fractionals to 1-1/2
DFB
Don't have to over buy many the larger sizes can cross over. Not always perfect but it often works
1-1/8" 29 mm, 1-1/4" 32 mm, 7/8" 1-5/16" 34 mm, 1-3/8" 35 mm, 1" 1-1/2" 38 mm, 1-5/8" 41 mm
I was looking for 1- 9/16 for a special project. A swivel base nut in a recess on Reed vise (guess a 39mm might have fit too did not have one) This thing was tight and a 6 pt chrome 1-5/8 was damaging the corners of the nut
So I ordered a 6pt Sunex impact delivered thru Amazon for less than I could buy any one impact locally but turned the standard impact walls were to thick to fit in the recess.
Thinking the axle nut sockets are slightly thinner wall too. I scored a herebrand 35mm at a flea mkt for couple of bucks that's a lot thinner wall
Ended up buying a cheap standard chromed one from Auto Zone they had a wide selection of large singles
bpankratz
Thanks for all the responses! I think my best bet at this point is to look for some 3/4" socket sets as some of you suggested.
Elsinore13
I was helping my brother in law clean up around an old house he had bought. Previous owner had a dozer he worked on and when he moved out left a mess of stuff all over. In the deep grass at the base of a tree I spied a big socket. Got to digging and found about ten 3/4 inch drive Proto's up to 2 1/4 inch. Decided to soak them in the Evaporust this weekend to see how well they will clean up. Not real pretty, they may get run through the blasting cabinet and treated to a coat of paint. Not like those will see much use, I don't even own a 3/4 inch ratchet.
unslow1
Illinois
Do you really want sets or just a few individual sockets? I have several extras and I'm sure others on here do also. Sets are the way to go if you want all of them. When you just need a few it's a lot cheaper to get them as you need them.
CR888
I have a PDF chart that shows all the torque parameters for hex bolt fasteners for all the different sizes. And obviously the bigger they get the more torque they can handle tested in lab conditions both dry & with lube. The problem IMO trying to buy large 1/2" sockets is that the torque properties of 40mm-50mm bolts exceed the capability of a 1/2" drive tools. I realise the OP is not necessarily trying to torque to maximum capability. For example max torque for a 24mm hex bolt is 445ftlbs (dry) so a 40mm would be massive! I think tool makers when warranting sockets have to think about these things more than we would think. Not having success loading PDF chart.
jalind
Northern mid-west USA
^^^^^ This.
It's about product liability. Manufacturers do not want liability for a tool (socket) that will invariably be used beyond design limits of the drive system it's put on. Even if you don't do it, someone, and more than just one, will do it, just because they can do it. Lawyers have a field day with stuff like this. ASME B107 is an industry standard that covers requirements for hand tools and accessories. B107.110-2012 covers socket wrenches and sockets. B107.300-2010 covers torque wrenches (the trailing four numbers are the year it was adopted). ASME is the American Society of Mechanical Engineers. When you buy a hand tool the manufacturer states complies with ASME B107, this is the standard they're using for design and test. These standards limit application of drive sizes. As an example, B107.300 for torque wrenches limits how much torque a given drive size can be designed to measure. The consideration is how much torque a socket put onto that wrench can withstand. I haven't gotten into B107.110-xxxx (for any year) and I'm not about to spend $100 for a copy (these docs are not free) but was able to find a free B107.300-2010. It's how I know there are limits by drive size on how much torque a torque wrench can be designed to measure, and be in compliance. I would not be the least bit surprised if there are limits on how large a socket can be made for a particular drive size, for impact and non-impact use, like B107.300-2010's limits on torque measurement for each drive size.
As others have mentioned, use a drive adapter to size a 3/4" down to 1/2" drive, but do so at your peril understanding the torque limitations of 1/2" drive compared to 3/4" and keep it within those limitations. A post in another thread bragged about putting 1200 ft-lb onto a SO 1/2" drive breaker bar without the breaker bar failing (IIRC "exploding" was the term used). Under ASME B107 that's well into 1" drive territory. Be aware that there is always someone around who will grab onto it and try to use it well beyond design or ASME standards limits, just because they can, and grouse about it to anyone who will listen when it breaks. Regarding the 1/2" breaker bar 1200 ft-lb event, the breaker bar and any 1/2" drive socket or other accessory that was used with it subjected to the same torque should be retired and destroyed or otherwise permanently disposed of. What you don't see on the outside are the molecular changes in the steel on the inside from the strain, which weakens the tool(s). It may appear visually to have suffered only elastic deformation (i.e. it goes back to original shape and condition) but internally at a molecular level (IMHO) there is without doubt plastic deformation (i.e. has new shape and condition). At some point later in its life, if stressed sufficiently again, even within ASME B107 limits, it may fail. IOW, it's a failure waiting to occur, like a land mine with a wonky fuse that might or might not work until triggered a number of times. It's one of the reasons I'm extremely loathe to loan tools to anyone, be they hard line hand tools or power tools, or electrical/electronic measuring instruments. If I do, it's under my supervision to prevent misuse and abuse. Too many do not respect tools they don't own. I see this routinely with monkey wrenches, especially older ones, with jaws no longer parallel and the back bent, from the obvious application of a cheater pipe. Just because the jaws could open 2 inches plus on a 10-12" monkey wrench, someone puts 800 ft-lb of torque on it to remove a 1-3/4" rusted nut and then moans about how the wrench is a pile of ****.
John
verbalkint99
I just picked up an Armstrong 36mm 6pt impact from Cripe for $10. They had a number of other larger 1/2 drive sockets in metric and SAE, but you prob wont be able to make a set if that's what you are after
