raspy
Yes I think where you live makes a difference. Here in the great white north you need insulation. I would also like to say I think I am correct on if your system isn't pressurized and is open to the atmosphere o2 barrier is a waste of money as your system will keep picking up oxygen from the air. Most outdoor wood stoves are this way. If your system is pressurized it is isolated from the atmosphere. and only the initial oxygen will react with the iron parts of your systen.
Dagny,
Please do some research on what "oxygen permeation" means. It has nothing to do with being open to the atmosphere or being pressurized. It's oxygen molecules permeating through non-metalic tubing from the atmosphere to the water in the system. System pressure has nothing to do with it. This occurs on closed loop systems and leads to rusting of iron parts. When there is an oxygen barrier, this cannot occur and iron parts can be used.
Non oxygen barrier tubing can be used with iron parts if a good corrosion inhibitor is used. This will coat the surface of the iron, aluminum and copper parts in such a way that the oxygen in the system cannot interact with the metal.
"Pressurized" does not have anything to do with corrosion or oxgen in the system. Better terms might be "open loop" or "closed loop". My closed loop solar and my closed loop radiant system are not open to the atmosphere and they are not pressurized. Sometimes they are under a slight vacuum and sometimes they may have a slight pressure increase above atmospheric, but they are not set at normal hydronic pressure of 12 PSI and they are not open loop.
The solar system is subject to possible corrosion because it has non-oxygen barrier, non-metalic tubing and iron in the heat exchangers and pump. But it has a corrosion inhibitor. It also has about 20 gallons of air (at normal atmospheric pressure) that can supply a lot of oxygen for corrosion. No problems with corrosion in the system.
The radiant system is closed loop with a non-diaphragm expansion tank in the attic that has about 3 gallons of air to stabilize the pressure. It uses 3/4" PEX throughout the floor with an oxygen barrier and corrosion inhibitor. No problems with corrosion.
