B-52 Superatchet
geo_08
So this may be the wrong place, but this is older and vintage-ish. Anybody know a good source for rebuild kits for these ratchets? Doubt the modern day stuff works.
davethorik
Norka, Ohio
You are correct, the modern round head ratchets from Williams use a single pawl 72t mechanism that is more like a Facom ratchet than the original twin pawl Superratchets. I believe your only option is to find a parts donor or hope an original repair kit pops up on ebay for a sane price...
rannoch
PNW
I just pulled apart my S-52 and found that one of the pawl pivots had sheared.
Also, no springs beneath the pivots.
my lock ring was surprisingly easy to turn with a pair of snap ring pliers
DadsTools
This. And if you do happen to find a rebuild kit that arose from never-never land, be assured you'll pay dearly for it.
I conducted some extensive research awhile back in the turbulent times at Williams Hand Tools (it's final name before going toes-up) during the 1980s. What I found was that the original factory and its contents were liquidated in the last part of the decade. When Snap-on bought it in 1993, all it acquired was the trademark and other remaining intellectual property. It was a company on paper. Snap-on designed and manufactured every one of its Williams from scratch in its own factories.
So, except for the names and perhaps some patents, nothing remained at the end of the 1980s of the old JH Williams Company. I think a west coast importer bought the name and held it for awhile before Snap-on. I'm sure everything in the place--including what rebuild kits might have been there--was scrapped.
DadsTools
I can tell you this, though, to help in your search. It won't matter if the ratchet is marked "JH Williams & Co", "JH Williams" or just "Williams", the latter with or without the "Superratchet" moniker.... the parts should all be interchangeable.
Hope this helps.
G
geo_08
Thanks for all The info, it was free so no worries if I can't get it to work. I will keep everybody posted.
Thoughts on age?
DadsTools
Thoughts on age?
Yep. Toward the end of the 1970s, TRW, owner of Greenfield that was owner of Williams IIRC, began to move away from mechanics theme and position Williams as an industrial tool, changing the name to Williams Industrial. First thing that was dropped from the ratchet was "& CO" tag. Next was dropped the "JH" and a font change, followed by the dropping of the "Superratchet" moniker. This should place your rat around late 70s to early 80s.
ken w.
Western New York
Every once in a while a rebuild kit will come up on Ebay. You would have to look every day at the newly listed items. I try to buy any Williams kits I can find. Here in the Buffalo area , the Williams tools are really drying up. Most of the Williams employees are dying off and I can't say where their tools are going. You just don't see them at estate sales anymore.
G
geo_08
And I suppose snapon even though though they have the williams name don't warranty the Williams ratchets? (Have another broken one).
ken w.
Western New York
A few guys tell me that a local supply house will replace the older Williams tools with the newer Williams from Snap On. I can't prove this as I haven't had a broken Williams tool in quite a while.
bonneyman
Desert SW
Yeah, I got a free one, and shopped around looking for a rebuild kit. Nada. So I'm left with getting the mechanism apart and salvaging the parts to get it to work.
RubiconJK
"I'm bad, I'm Nationwide"
Twertsy has some very good info on Williams on his ToolArchives site. Others may be able to help you with your date question, but since your ratchet has stamped lettering rather than forged I would guess that it is a later production article.
mikebaker1129
Huffman,TX
A donor ratchet is a better bet and an easier find.
I did purchase some kits for s52's on eBay a few years back. Repair kits for this style Williams ratchet hardly ever turn up forsale.
A good cleaning might get your ratchet working again.
mikebaker1129
Huffman,TX
I have a few odds and ends for this style 1/2 S52 ratchets.
Those that are missing parts/ have parts missing send me an email or pm and I will take a look and see if I have what you need.
G
geo_08
I'll get back to you in that. I left it at work for the weekend.
mikebaker1129
Huffman,TX
My parts are at work, so that works for me!
Just to be clear, I only have parts for the S52 which is the 1/2 big brother to the B52.
I do see the Older B52's around here in the $5-8 range at fleas and pawns,should I be picking them up ? I have a few S52's,B52's and1 lonely M52.
I live just outside of one of the largest petrochemical complexes in the world, so certain JH Williams,Proto and Armstrong tools are pretty common around here,usually found in pretty tired and abused condition.
exmaxima1
Midwest
+1
Sent in an old 3/8 Williams Superratchet and Snap On mailed me a free replacement. Actually pretty nice ratchet, still a bit stiff though. Can't complain.
rannoch
PNW
In case it's useful, over the weekend I replaced the pawl pivot with the shank of a drill bit that I cut to the right length and replaced the missing springs under the pawl pivots with short springs cut from a clicky pen.
The ratchet is a bit stiff but it works much better than it did before. :)
p.s. Assemble/disassemble this style of ratchet in a clear baggie of some kind.
Those ball bearings can go quite a distance.
DadsTools
Way to go!:thumbup:
And yes, those ball bearings do tend to slip the surly bonds of earth and pass into the great beyond.:lol:
My biggest complaint about the RH Superratchets has always been the backdrag on them. However, I have a 1/2" on hand and use it when I have an old stubborn nut with a lot of crud on the bolt and the tight clearances where I need the fine teeth for. In such cases, backdrag matters little. You just about only have to show one of these rats to the nut and it kind of scares it loose. :scared:
Here is a pair of Superratchets that I’ve been hanging onto.
Beerman
West Columbia, SC
Funny, you mentioned the M52. I got to the local flea market WAY too much. I see 3/8 superratchets for sale 1-2 each month. I see the 1/4 version about once every 5 years.
notlob
norcal
I've been looking for an M52 rat for years. The few sold on eBay are apparently made of gold.
mikebaker1129
Huffman,TX
I finally found a M52 in the wild about a year ago.
I just picked up a 3/8 Williams palmster ratchet, it is a handy little ratchet.
RubiconJK
I found this B-52 at the flea market today. Just a minor bit of clean up and it is good to go. My father used Williams ratchets his entire career in the oilfield and swore by them.
1320
Arizona
The B52 is the Stratoratchet, the B29 is the Superratchet...
Sorry, sorry...
Cruzan80
Denver, CO
Yeah, I have about 4 b52's, about 3 s52's, and only 2 m52's. Both local (well, one shipped in from about an hour south of me), and they are the only two I have seen. Second one needs to be disassembled and cleaned well, fairly sticky. First one is really nice.
Sunset_Z28
Harrah, OK
The flea market you go to doesn’t happen to be Mary’s is it?
