"Build" a Matco swivel ratchet for $33
rattler459
i am not against making stuff and i was tempted to as well. i just couldn't see cobbling something together for more money. this is an actual ratchet hanging on the shelf at every home depot.
the same style of mechanism only in a dual pawl with 100 clicks and a working lock on the flex. other than tooth count the mechanism is the same as a gearwrench 120.
Have the same one and have worked it hard and its a great ratchet
AngryBeaver
Lake Milton Ohio
mine got a Kobalt handle from lowes. it fits in the work truck great. sorry no other pics lol
Specs
The other side
start here for $25:
Edit,
new listing again (3/1/18 5:45pm), $29 now:
https://www.ebay.com/itm/NEW-MATCO-...OCKING-FLEX-FLIP-LEVER-COMPLETE/263526402120?
add one of these for $7.31
https://www.amazon.com/dp/B00V3X3NJS/?tag=atomicindus08-20
add a small O-ring & a stainless 10mm flat washer in the recess on the head for tension,
bolt it together with one tiny drop of locktite, and its good to go.
Blame me I bought 2 heads. I’m on the fence about making it fully articulate, when I only really need that 0,5,10* offset I get non modded. The thing is crazy snug when you make the bolt flush. I carry a 4mm allen to adjust the firmness;)
I did pack some super poly lube to quiet the internals and neck. I wanted to give you a rep... :headscrat And it fits perfectly in a 16” tool box. Thanks again i hope to return the favor with some of my own ideas
J
Ji m
The Northeast
I'm glad the seller keeps putting these up,
since I haven't seen them anywhere else yet :thumbup:
The first bent one is my go-to 3/8" now,
& I'm resisting the urge to do a super-stubby next.
Capri handle is still a good deal for the $$,
so I think I'd just chop one in half and press on a Matco hard handle on the end.
Interesting idea about not clearancing the handle opening and using it with the limited travel,
I didn't like the feel of the two pieces interfering with each other,
but can see the benefit of them not being able to flop beyond a certain point.
It's cool to see pictures of what everyone put together & how they worked out, thanks! :rocker:
AngryBeaver
Lake Milton Ohio
mine with the Cobalt BB handle goes about 45* each direction before any interference and will go 90 with force. I didn't grind it due to the nature of it living on my service truck and moist/condensation in the tool box bed from temp changes didn't want extra rust occurring. I had an extra spring washer in my drawer of parts I was able to put in the ratchet head since the BB nub didn't have that setup.
I too thought about grabbing some kind of hard grip handle for mine.. couldn't find a cheap enough BB with a hard handle tho.
my stubby flex Snappy is one of my favorite ratchets... so I'll fuel the fire and tell you to go for it. lol
KnurledNut
n/a
The real question is, where is this dude getting all the brand new heads from?
All the tools for sale are Apex brands or machining supplies.
The ebayer is based from Little River, SC.
The tools probably originated from the neighboring town of Sumter, SC, where Apex moved and then closed most production. Which, needless to say, was a total disaster and waste of time and money.
Odes
Newfoundland
Here is mine I made I used a husky Cb-64 that I paid $10 at the flea market just had to grind a little bit for width
J
Ji m
The Northeast
That looks good,
thanks for the pic :thumbup:
I have a 3/8" Knurled Husky BB that looks like that (pn 22232), and was wondering how it would fit.
Though I think I'd want to chop it down for a stubby.
My 22232 has a pressed in pin, and no spring loaded ball bearing, so I'm not sure how secure the head would be,
or if it would flop around without being able to tighten the screw. :dunno:
Specs
The other side
Update: dremeled the corners and red thread locked it... still snug enough to not go floppy, cause that capri bar is longer than my bluepoint flex bar by 2”. Im gonna take advantage of the length. I used the conical stone that could be used for engraving, doesnt even look like i did anything
PR1Gneon
Sent from my SAMSUNG-SM-N920A using Tapatalk
Specs
The other side
Harbor freight has a 3/8” dual flex handle ratchet thats not much bigger than that...pic is just for reference
ngk22r
Also,
the Matco head has "88" inside the Matco symbol,
but doesn't list COO anywhere on it.
I guess I'll assume USA, or maybe Taiwan unless someone says differenly.
Action feels great, and this is the type of ratchet with the little floating latching piece inside.
The Capri handle has COO listed as Taiwan, and a 159 ft-lbs rating on it's hanger card.
It feels quite nice,
has a spring loaded ball bearing to lock the head into position (which even my Snap-on FDLB 3/8" breaker bar is lacking)
though there is an Amazon review showing atleast one broken one.
I like it so much I plan to build a second one and not bend the handle on that one.
The COO is not on the head but rather on the handle portion of the ratchet.
PR1Gneon
Re: "Build" a Matco swivel ratchet for $33
The short handle is part of a Gearhead double flex ratchet from Pepboys.151d0a7d6af3e3578abd13f0be09d825.jpg
Maybe the same as the Pittsburgh
J
Ji m
The Northeast
Thank you.
With all the Matco to Gearwrench similarities I thought Matco may have moved production to Taiwan like I believe is GW's COO,
but after reading and watching video's here, I'm pretty sure Matco ratchets are Made in the USA still :beer:
I'm glad, because the action on this "88" is really nice, and it's good to see USA production quality can still keep pace even when the item cost (like this inexpensive head) isn't that high. :pimpflash
J
Ji m
The Northeast
PR1Gneon
The Gearhead flex handle works good too.e3df9d23719e50b5a2829c9c59058497.jpg
ngk22r
Thank you.
You would be correct:
seber
Deep East Tx.
I found a Wright soft grip on fleabay for $12 with shipping. The handle from one of those cheap four way screwdrivers is a perfect press fit. I did have to file some clearance for the ratchet head however.
It's my Wratco ratchet.
PR1Gneon
J
Ji m
The Northeast
I used your tip :thumbup:
I got the Taiwanese HF double flex (96369),
and used the lower portion like you did.
The opening did not need to be opened up, or clearanced at all like the Capri did,
but it is slightly wobbly (I may try a thicker lock washer in the Matco 88's recess to compensate).
I really like this as a stubby flex head,
I didn't want to just toss out the rest of the HF Pittsburgh ratchet,
so I put a throwaway, junk bright orange CM handle on it to make a second stubby flex head for my travel bag.
Thanks!
notice how much THICKER the HF head is compared to the sweet Matco 88 :pimpflash
^I also swapped a dual-drive 1/4" 3/8" HF gear into the Pittsburgh ratchet just to try it out.
I don't think I like it. :eyecrazy:
J
Ji m
The Northeast
Frankenstein family pic group shot:
^ including the Harbor Freight 96369 red headed step brother made from leftover parts :wtf:
so is this a silk purse from a sows ear?
or $106 down the drain?
I think I really am finished this time :lol:
Specs
The other side
Having a mess of ratchets already, it’s definitely a silk purse cause the head is not too big and reaches in where i need to and saves some steps in getting a breaker bar
seber
Deep East Tx.
Well now that I've done a healthy project with the Wratco ratchet and had plenty of time to evaluate it, I've gone back to my old 30 tooth Snap-On. I wish I could explain why but it just works better for me. I should mention that for me the main advantage of a flex ratchet is using it as a speed wrench.
Yarpo
Minnesota
RH2
After looking at this thread, does anyone know what handle fits best here...preferrably with no modification? I have the Kobalt flex handle ratchet and it looks like the shoulders on that are much wider than the Matco head. Any ideas of a direct replacement?
Thanks,
Robert
Whoismiked
Texas
I know this thread is several months old now but does anyone know a place to get and heads anymore? I would love to make something like this.
isuhunter
We don't have a pepboys in the area and I want to turn mine into a stubby. What other stubby handles have you guys had luck with?
Specs
The other side
Update: Since people were clamoring for new head combinations, did some grimy research, found that Kobalt PRO90 flex head ratchets in 3/8, fit like they Belong on a Capri breaker bar. No grinding down required. So if you find a Stubby 3/8, or Break the collar that holds the head, on any other length kobalt flex, You can order the Capri bar and drop it in. Beware, Lowe’s discontinuing Kobalt, so you gotta make moves for the head...
#0337332 is the part number on front
#85863 is the number on back...
Happy hunting
