I got a free air compressor from my uncle.
rmsawyer73
Hi I got this new air compressor from my uncle and I have no idea what it needs to make it run. When he gave it to me he said he was pretty sure the electric motor wasn't working anymore. Can I buy a new 110v one so it would be easier to hook up in my garage? I only need light duty stuff I'm not running a commercial shop here just some hobby car stuff and a small sand blasting cabinet. Also the head makes compression and you can feel/hear the air coming out when you spin it by hand and the pulley is 15" wide
Sent from my XT1585 using Tapatalk
confederatemule
Before I'd buy a motor I'd have this one checked to see what the problem is. It may be somethin very simple and inexpensive. Five horse motors are expensive.
redmondjp
Redmond, WA
You may want to have a motor shop check that motor out - it could be something as simple as a bad centrifugal switch inside or a bad motor capacitor. That motor is going to cost around $300 - 350 to replace, and before you do that, I'd want to make sure that the pump is OK first.
FTG-05
TN
Doing some quick research, the smallest sand blasting cabinet that HF sells requires 9.5 to 10 cfm at 100 psi. That would require about a 2.6 hp motor (or 3 hp to round up at 3.8 cfm/hp).
You can get exactly one 3 hp electric motor from Surplus Center that runs off of 120 VAC; it requires 33.6 amps to run; hence almost certainly requiring you run a new circuit anyway. And this motor costs $845.
A standard 5 hp 230 VAC motor (also from SC) costs $220. Certainly you can run a 220 VAC circuit for less than $550, yes?
As stated, make sure to check this motor out first, it might be something simple. I would never downgrade a compressor just because of a (fairly) simple circuit.
6PTsocket
And the tank.
Lassen Forge
1ø 240? Common as dirt. Worst case scenario you'll have to have the motor rebuilt, cheaper than replacing it. Take it to a motor shop and have them go thru it. That's what they do, and it's cheaper than a good, new motor.
Plus, to put a 120 motor on that you'd have to run a new 60 amp (!!!) 120 circuit (IIRC the formula is 10 amps per HP + 20% safety factor) and heavy as hell wire, and enjoy all your lights dimming every time it kicked on, so you'd be WAY better off running a 240 circuit and doing it right...
R
rmsawyer73
I will definitely keep it 240 then. Im going to do something like this
. The compressor will be down in the basement right by the panel so it should work out right? Just wire up a plug to the pressure switch and hopefully that still works. I'm going to sand and paint the tank any recommendations of good paint?
