yeah its sink only. The slap is not poured but the footer already is.
Was looking at an under the sink utility pump.... something like this maybe? anyone have experience with this?
https://www.homedepot.com/p/AquaPro-1-3-HP-Utility-Sink-Pump-55011-7/206852252
I have a pump similar to that one. It is made by a company called Shellback. The housing and other parts are all brass, copper and metal. It costs about twice as much as the one you have shown. When I bought it 16 years ago there were really no other options available at a lower price.
Here is the one I have:
https://www.homedepot.com/p/Shellback-1-8-HP-Laundry-Tray-Pump-3-12-19/206374855
I bought mine back in 2002 along with the utility sink. Both are installed in my basement. I put a brass check valve on the output pipe instead of a plastic one for longevity.
This thing can pump out water fast! And it can also pump out objects up to a quarter inch in diameter. Anything bigger than that will get hung up inside the impeller. So I keep a screen inside the sink drain hole to keep **** out of the pump.
My set up has the pump pushing the water out of the sink and up about 6 feet to the ceiling of my basement. From there the drain pipe slopes down into the main drain where the clothes washer drains into. It doesn't even blink at that pushing the water up that height.
If your garage will not be heated, and it gets below freezing out there, then I don't know how this type of pump will handle those temperatures. Mine is in my basement, and the temperature never gets below about 56 degrees.
What I like about these types of pumps is that they don't have any type of venting piping like some utility pumps have/require. As long as the drain you are pumping the water into is not completely sealed, these types of pumps will work for your application.
Now that being said, these types of pumps might not be completely code compliant in some locations. So if being up to code matters to you, then you might want to check with your local municipality to see if this type of pump is ok to have for your purpose.
Jim
