I have a pole barn built with with trusses set at 48" on center. I'm working on finishing the building with electrical, heat, insulation, walls and ceiling.
Can OSB span 48" OC trusses with blown insulation for the ceiling? If so what size OSB?
Is there an easy way to make that span less (without toe nailing 2x4 every 16" or 24" in between every truss)?
