11555wally
- Joined
- Nov 24, 2017
- Messages
- 18
I have a pole barn that is about 45 years old with a metal roof and nails for fasteners. The rubber washers on the nails are starting to fall apart and I have some leaks that I attribute to the bad washers. I plan to remove all of the nails and replace them with screws with rubber or neoprene washers. The nails are on the ridges of the metal roof and when I pull them I will deform the ridge a little bit by forcing a catspaw under the nail. I'll put a piece of wood across the ridge to pry against to lessen the damage to the metal ridges. My question is do they make screws with larger washers that would better seal the metal where I may have bent it in during the nail removal? Thank you for any help.
