Lowes Utilitech LED T8 drop in bulbs closeout
Falcon67
Merkel, TX
Was in Lowes Saturday and noted that they are closing out their Utilitech brand 4' T8 LED drop ins. $9.99 for a 4 pack, bought two 16 packs of 6500K for $39.95 a box. This store looked to have 6500K and 5000K on the shelf.
Allowed me to do the other 6 fixtures in the shop and the race trailer with a couple left over for spares. Offered FWIW.
Saved to old T8 6500s and will take to the ReStore.
aka Larry
Eastern, NC
Did you miss my post about this last week? They had the same deal at my store so I bought enough of the 6500K tubes to retrofit my entire shop (40 tunes) for just a little under $100 + taxes. Good deal for sure!
I donated all my old T8's to a local church so they didn't go to waste.
Crazyjake8493
Upstate NY
Just so everyone understands - These Utilitech bulbs (link) require a fluorescent electronic ballast.
Unless you can find item number 778115, but I had no luck anywhere around here. I needed direct wire LED's.
Also they do carry LED tubes that will work with T12 magnetic ballasts, but only one item here, a GE 2-pack I think, for $14.98. The Utilitech LED's are an ok deal if you already have T8 installed.
F
Falcon67
Merkel, TX
Apparent not LOL. Worth a duplicate maybe anyway.
Yes. I rewired one fixture in the trailer for direct wire bulbs. It was a PITA, required new tombstones and cost more than I expected - about $40 when done. So I just went with drop ins.
Platonic Solid
CT-USA
The newer universal lamps are easier. Both the Greentek (link) and GLLUSA (link) bulbs are universal, so no lamp holder issues.
GRB
SoCal
Just because they are marked down doesn’t make them a good deal. I wouldn’t take these for free.
In The Doghouse
South of Due West, West of NinetySix in SC
I bought a bunch of these Utilitech 0852829 T8s for about $2/bulb and replaced those in six fixtures, each containing 4 bulbs, in my backyard shop. I experienced an immediate improvement in lighting over the fluorescents and I was happy.
Now one fixture fails to light. Reading this thread and some others it seems I have to replace my ballast to rectify the concern. I guess my purpose of writing this is to warn others to source LED bulbs that do not require the ballast.
Edit: A photo of the ballast is attached. When can I get a cheap replacement?
cybrdyke
USA
Lowe's should be able to provide a list of ballasts that are compatible with their lamps.
Dont assume that any T8 electronic ballast will work.
CD
Crazyjake8493
Upstate NY
CD
Lowes hasn't carried Utilitech LED tubes since last summer, so I doubt he'd have any luck asking Lowes.
I would just replace the bad ballast with whatever T8 electronic ballast was available, I'm sure the majority would be compatible with those bulbs.
cybrdyke
USA
Yeah, that was my point.
They weren't able to provide that info even when they did carry them.
That's a **** shoot. But your best chances would be with the Philips/Advance ICN series, Universal B232 series, or Sylvania QHE series.
CD
In The Doghouse
I bought an $8 ballast from Amazon and my light now again functions as it should. The other three fixtures on this switch start almost instantly while this repaired unit pauses for a moment. The pause is probably due to the new ballast, it must be a slow starter.
I purchased one of these:
General Electric GE432-MVPS-L 4-Lamp Program Start Ballast, T8, 120-277V, 60HZ
cybrdyke
USA
Norcal
cybrdyke
USA
Since they are a major supplier of lampholders, it does make things more difficult to do, & I doubt they the only one.
I've asked them several times for an explanation of why they say this so adamantly. I've never received an answer. I mean, the socket is rated for 600v, and a ballast delivers a lot more than 120v, so I dont understand why. But, they are pretty insistent about it.
CD
Bib Overalls
Jonesboro, Arkansas
I did this several months ago and I am very pleased. 26 tubes in all. Bought all they had and thought that was it. Next time I came in they had some more so I bought enough to finish the job with a couple of spares. T8s went to the Salvation Army.
ichabod
minnesota
CD
it might be that when a ballast is supplying the power to the tube, the ballast is limiting the available current to the sockets. but when ballast has been removed the only thing that is limiting the current is the breaker. so I might guess it more of a current rating then a voltage one, but I might be all wrong here......
