jpcjguy
Hi all,
So I had older thread on this located here:
https://www.garagejournal.com/forum/showthread.php?t=277109
After doing more homework with the power company and the local inspection office, I have plan!
Just to make it clear - New service is out - too much $$$
So I have twin 200amp panels in my garage. The largest breaker I can get for the panel is a 125. I talked to the building inspector and he agreed that I can tap into the meter directly and go to an external disconnect and then go along the side of the attached garage (buried next to slab) and then under the house and come out the corner and trench to the garage. Looking at another 200amp panel for the garage. Will have compressor, welder, future lift, and possible future HVAC for lower and attic truss space. Basically want to future proof it within reason.
This leads me to another thought - I currently don't have a good generator solution. Nowhere near the house that is visual friendly to put one. Being able to put a whole house behind the garage would be great - could even be propane based, since it would all be hidden. This would mean "backfeeding" to house. Problem is that I am tapping off the meter - not a panel in the house. Any creative solutions that anyone can think of? Too much work for not enough value? Would the wire size between the garage and the house have to increase significantly, thereby increasing costs to "not worth it" land?
So back to the normal wiring. What kind or external disconnect would I need? Something like this:
https://www.homedepot.com/p/Eaton-200-Amp-Enclosed-2-Pole-Outdoor-Circuit-Breaker-ECCVH200R/205936221
As for the wire size and type, figuring on about 250' from the meter - along the house, around the septic and to the garage. What do you all recommend?
The route will be pretty much the blue line in the below picture:
