Sawzall blade
PugetDude
Superstition Mountains, AZ
I buy mine from Cripe Distributing- they have a ever-changing inventory of good name brand blades at really good prices, usually in 5-packs for around a buck a blade.. I've used Dewalt, Bosch. Lenox, Makita-have had good luck with most of the name brands.
FTG-05
TN
I use Diable Carbide blades. They are designed for heavy metal. If it's thinner metal, I use the Diablo metal cutting demo blades.
KnurledNut
n/a
I did this with only one used Lenox Gold blade.
The blade pic is after the cut.
I dipped it in water throughout.
Heat will cook ANY recip blade.
kctyphoon
Jersey/Staten Island
Milwaukee.. for sure.. they are THICK, quality blades that will not just bend if they bind up slightly.. at my last job, I used only Diablo until the Milwaukee's came out. After using the Milwaukees, I think I had 200 delivered and given out to the rest of the guys I worked with. They make thin kerf blades as well, but the regular blades seem to be the best I've used. I don't buy any others.
You are better off cutting slower on thick metal with a sawzall. Excessive heat will kill any blades. This is a good demo
sk farmer
nd
best advice. any decent blade will cut well. run the piss out of them and they are all ****.
DFB
Southern VT/Western Mass
Ya match the tooth count to the material/thickness
I have always had used Lenox on my job as it was easily found and always work great but the new Milwaukee blades are real good too
I have a couple of 100 ct box of Dewalt 14tpi 4808's I sell off on my tool table so I often just use them as needed :D
They are ok for middle of the road cuts on most things
geojag
Little Rock, AR
The Diablo carbide extreme metal blades are hands down the best metal blades I have ever used. I used Milwaukee Torch before, these are 10x better. If I can't have a torch, I'll take these.
I have cut all variety of steel and cast iron. A lot of first responders use them to take apart cars.
Sent from my Pixel XL using Tapatalk
