seagull369
- Joined
- Jan 16, 2013
- Messages
- 227
I just wanted to double check with you guys before doing this.... I bought a 240V compressor which has a plug similar to the one shown in the pic on the left. The outlet I want to use for it in my garage has the style to the right.
The plug on the left, it seems, has a ground on top and either parallel pins are the hot leads. I'm pretty sure the receptacle on the right has 2 hots again but one of those (maybe the bottom one) is for neutral.
My question is, would it be all right it I swapped the plug on the compressor to match what I have in the garage and make make the ground on the compressor end go into the neutral line? That 240v outlet goes directly into the breaker and no other outlets in the circuit
