The VISES of Garage Journal
gman007
West Michigan
Good buys outlaw and the vise came out awesome gman.
To my surprise it’s a Reed 404-1/2. Not a huge vise any swivel jaw for $50 is a deal in my book.
Bagged
Thank you for the compliment.
You did very well on the Reed, $50 for a 404-1/2 is a great deal all day long. I am sorry I can not help with the size of the pin but as for handle, even though it is pretty badly bent, you might still be able to straighten it using a hydraulic press.
454ragtop
Carver, MA
Bought my first bench vise at a swap meet over the weekend ($25! :rocker:). Dunlap brand #5244 with 3.5" jaws. Dirty, but has a lot of potential:
I'm going to use the threads on here to clean it up and properly restore it. Anyone know where I can get some new jaws for this puppy?
Thanks!
Saw that one at Lake Compounce, already have 2 examples, so it was easy to talk myself out of buying it. Well made vises for what they are, see one I restored here https://www.garagejournal.com/forum/showthread.php?p=4532367&highlight=Dunlap#post4532367
Here's my vise take from the same swap meet, a Wilton combo wood, bench, pipe vise, a Fulton 2-3/4" jaw enclosed screw vise, a small hand vise, and the 3-1/2" Craftsman.
zbyler That will buff out!
Bagged nice score! Can't help you on the pin but I suspect they should; try this: swing the jaw out of the way ad see how the pin fits in just the lower end...
454: great scores!
Miller72
Connecticut. Home of Collins Axe and Charles Parke
I found this screw vise again in the basement. I can only assume it was my grandfathers(mom's dad), he passed away in the early 1990's at 93. No one clearly remembers him using this but my dad vaguely recollects him having it at his garage bench. Now I own and am raising my family here in there house, now ours.
I have my bench in the same half of the garage he once used as his shop as well :thumbup::thumbup:
Instead of moving it again and telling myself to go make use of it...I decided to actually go and make use of it this time...so I decided to break it down to make the vise a vise again :beer:
Cut the single piece of probably near 70/80 year old oak to make two 12" jaws.
I need to replace the one rod, rusted, stripped and bent a bit.
It will sit here in it's on deck box awaiting parts, cleaning, lube and then mounting:thumbup:
PHP:
ALLFAST
Bagged, the pin that holds the rear swivel jaw fast is called the taper pin. Each bore should have it's own specific angle to match the taper of the hole. I understand them to be expensive to have custom machined, but I could be mistaken. Yes, that's a good buy.
pelletman
Worcester, People's Republic of Massachusetts
Picked this up at a flea market over the weekend for 10 bucks. I tossed it in the molasses bath yesterday and I will check on it in a week
BillyWhitehorse
So I got the Reed today. It has a very nice patina on it. I'm hesitant to restore it. I think I will keep it, get the schmoo off of it and use it as is. I'm think I'm going to replace the Colombian with the Reed and sell it. I really hate to sell the gray Prentiss but...I don't really have a need for it.
I like having a 3" vice for smaller stuff. What would y'all do? The 3 1/2" Prentiss is a bit too big to use. If I could find a 3" one, I'd like a matching set for the garage.
Hi, some great restoration work there! I recently saved an old Colombian swivel vise from the scrap pile, but it needs work. A 203 1/2, I believe, pre-1973 from what I can find on it, I believe much older. I need a bench vise, but I’m not experienced with restoring them. One jaw is broken, and appears to be pressed/pinned in. Any tips on getting it out, or should I just cut it out, drill and tap for a new jaw? Thanks for any input.
bagged89s10
CT
I will machine one to fit on my lathe once I figure out the correct taper. Someone suggested using something like silly putty to make a quick mold to reference.
Dr Scott has the pins. I'd bet he will know of the taper is different. Heck his site may list what they fit...
He doesn’t but he gave me insight on how to measure the taper. Attached is what Kevin shared on how to calculate it.
gman007
West Michigan
Bagged
How about lubricating the hole (say with WD-40) and then pouring hot wax into the hole to make the mold. It might be a more precise mold.
MayerMR
Dallas, Texas
Bagged
Something that I've found that is even easier and less messy than wax for mold making is the *exceedingly* cheap modeling clay that you can pick up at Michael's Crafts Stores, and I'm sure online. It's very easy to use, just mold it with your fingers or press into the desired shape, throw it in the oven for about 30 mins at something like 230* for a hardened model!
va.grouseman
Southern-Central VA.
Billy, if the jaws are pinned in you can take the slide all the way out and knock the pins out from the bottom.---Sometimes they/the pins are hard to find because they are covered with gunk.---Just take a wire brush and give the bottom a good scrubbing and you will probably see them.
gman007
West Michigan
My point was that the liquid wax should fill up the hole completely as opposed to a soft solid such as silly putty or modeling clay that needs to be pressed into a the hole and which might or might not completely reflect the shape of the pin/hole.
va.grouseman
Here's a few small anvil vises I've acquired.---The 2 conventionals I've shown before, but I found a clamp-on that kind of complements them.---None of them have a true makers mark.---The seller described the clamp-on as a Russian made vise but I got my doubts about that.
zbyler
CT
Funny that you knew exactly where it was from. First time at that swap meet, and my first vise. Thanks for leaving it for me!
Nice haul also.
I'll shoot you a PM with some questions on that Dunlap vise.
va.grouseman
Here's a few more.
gman007
West Michigan
VA Man, you always find such neat vises. Very nice and impressive :thumbup:
Now, of course you are going to mount and use them, right? :evil::bounce:
And I am sorry but no you can not quote John 8:7, it was already quoted by someone else :D
va.grouseman
No Gman, I've got a 16 lb. sledge I'm going to take to all three anvils to see if they can carry the weight.---And they better measure up or I scrap these 3 and get 3 more.:D
EDIT---I might actually use the clamp-on some.
Razorhunter
No need at all to make a taper pin mold. Just neasure your minor dia (bottom) and major dia (top) and get tour length. You now have your taper in about 30 seconds.
bagged89s10
CT
Nice haul also.
Where in CT do you live?
davethorik
Norka, Ohio
I've been on the hunt for one of these a while that wasn't stupid expensive and/or broken...Letgo for the win yet again!! Handle not even bent!!
Stanley Victor clamp on vise...I believe it is a no. 743, however can't read stamp until I clean it up a bit, all I can make out is STANLEY VICTOR. 2" jaws. Some original paint present, rust doesn't look too bad.
$5 :rocker::rocker::rocker:
Evilunclegrimace
Erie Pa
I found this little vise while cleaning my dads work shop. It is a Brink & Cotton 149-8. It has a coat of red paint. Any ideas if this is a factory color and and ideas of a value on it.
It seems to be in good shape, the jaws are 1 5/8" wide and open about 2". The bench clamp will open to about 1 3/4". Thanks.
**** i can't get the picture to load.
davethorik
Norka, Ohio
From what I can see googling, fire engine red looks like the correct color. Value? Probably $10 or less.
davethorik
Norka, Ohio
Did some cleaning with mix of hot water, Dawn dish soap and Simple Green. Stamp is now legible, it reads
STANLEY VICTOR
No. 743
STANLEY RULE & LEVEL CO.
NEW BRITAIN, CONN. U.S.A.
PAT'D JAN 28, 08
so does this mean the vise is pre-Sweetheart?
Patent appears to be 877,695 by Joseph G. Baker of Philadelphia; listed as uassigned:
http://www.datamp.org/patents/displayPatent.php?pn=877695&id=52290
https://patents.google.com/patent/US877695A/en
mikeswrenches
Dave,
"so does this mean the vise is pre-Sweetheart?".
Yes. The S. R. & L Co. merged with the Stanley Works sometime around 1919-1920. After that, until around 1935, tools were marked with one of the three Stanley Sweethart marks, depending on the year of manufacture.
Mike
scooternut
Pittsburgh, PA
Thought i was heading out to buy a Reed 103, as i know them well, and found this Yost 103! Followed up a few days later by the Reed 104. Excellent tools, love my Reed vises.IMG_3802.JPG
davethorik
Norka, Ohio
Dave,
Mike
Thanks Mike, cool to know this vise could be 100+ years old! And still in good shape!
FMC1959
Montreal, Canada / Upstate NY
Poking around the Internet, I actually found a pair of NOS Record 634 pipe jaws in the UK after looking on a rare occasion for a few years.
They just arrived today (someone in the Royal Mail was kind enough to have sent them Air instead of Surface :D).
A quick scrub up to remove the packing grease and pop them in place.
The vise takes three of these so I will look into getting some more fabricated.
One note is that the teeth (since we’re talking about teeth) are not the same size and gradually shrink towards the centre.
Thrumcap
:canada:
THRUM, IIRC, you got a 634 a couple of years ago, now you got 2 more!!! Awesome score:thumbup:
If ever you want to sell one, PLEASE let me know:)
Oldie, I hope they find its something easier to treat than COPD.
My biggest vise score happened today. No Usuck prices here, I went to my first auction in decades, and I'd class this one as my first, "pro" auction, complete with "buyers premium" (as in lets **** the buyers for even more than we **** the sellers...)
Ah well, just make sure you figure thst into what you bid...
What got me there was the description, and the pic of 7 vises, all looking pretty good!
So the auction starts on time. I spent the first third just watching and learning, as they were selling stuff I wasn't that interested in, or was WAY over priced for what they got. Very few "deals"
We move into the "shop" area, and more stuff I wasn't bidding on; I thought I might if the Anvils didn't get into stupid money... a pretty nice portable forge came up and went for stupid $$... I was not getting good vibes for when the vices finally came up. a Baldor 3/4 HP buffer on a Baldor stand came up and I let that go as well as it was near into stupid $$
The anvils went for breathtaking sums! Stunningly the smaller one went for as much or more as the one 2X its size! (A Vulcan).
A lot more stuff I wasn't bidding on... FINALLY they went for the vises, (had to practically beg then to do them). First up was a 5" Wilton bullet without a base. otherwise in GREAT condition (all the vises were in great condition, however there were not 7 but only 4. (Someone cherry picking? )
I won the Wilton with my last bid and then would have let it go.. NOT stupid $$ and I can make its cost and then some back...
Next was a 4-1/2" Rock Island Pattern Makers vise and I bid and bid as with the Wilton and got it for less than the Wilton! and AGAIN, at my limit! I was happy about this one as its my first pattern makers vise, and a good one! I've been wanting one for YEARS!
Third up was Prentess fixed base, swivel jaw (missing the pin) and I again won at my limit!
the fourth was a Columbian and I let that one go, it went at a good price for the buyer!
And the main event! the vises, in the order won!
The Wilton:
The Rock Island:
and the Prentiss:
OUTLAW, great score :beer: All very nice, but have to echo previous comments, that RI Coachmaker's is a beauty.
When I was in the Air Force, I had an "In" Box, an "Out" Box, and a "Ponder" Box on my desk...If it stayed in the "Ponder" box for over 90 days, and no one asked me about it, I put it in the round file...
As one ages, one ponders about "What might have been...if....???"
I smoked for 54 years...
It got me an Abdominal Aortic Aneurysm, that damn near killed me...
The never ending fear that Lung Cancer awaits around every bend...
And now my Doctor has told me that I "probably" have COPD (Chronic Obstructive Pulmonary Disease...)...Oh Joy!!!
Now I'll have to deal with the COPD, but do you know what really pisses me off about smoking that long???
I smoked up...
1.) THREE Porsches...
2.) FIVE Really nice Pickups...
3.) ONE Really nice HOUSE!!!!
That's what pisses me off!!!!!
And what kind of "What if's", do you ponder???
OLDIE, nothing but hopes and prayers for you. You are destined to get a 5197/98, so you aren't going anywhere anytime soon :thumbup:
And a few more photos
GMAN, absolute beauty :bowdown:
BillyWhitehorse
Thanks! I’m debating about that step, because I’m unsure if I can get a replacement.
twertsy
Reedville, VA
Razorhunter
Hey guys, couple of Reed questions that I'd like to get cleared up.
-What was the general consensus on the "A" models, which I've seen very few of? There is currently a Reed "204A" on ebay right now if anyone cares to have a look. Ive seen them mentioned in this thread before, but I'm still wondering what, if anything, is unique about them as compared to any other Reed 204?
-Also, can you guys tell me what makes an "R" model vise, an R model vise? I had been thinking the R model vises were the snub-nosed, split collar vises. However, I recently came across a Reed R model vise, and it did not jave the snub nose spindle. It had the older, spherical, art-deco style spindle, in conjunction with the split collar. Thanks for any help here guys.
ETA: Tell me what you guys think about this. Shown, is what we normally think of as Reed "200" series vises, such as 204/204 1/2/205/206 etc. These vises are fixed jaw-swivel base. However, catalog page here shows them as "100" series vises with "S" notation. Such as 104S/105S/106S
Well dang I hope you guys can see the pic clearly. Its a screenshot I stole off the net and it basically shows all the fixed jaw, swivel base vises on the top right of page, as being "100-S" series vises. In other words, 103S/104S/105S/106S, as opposed to what we normally see as 203R/204R/205R/206R.
Can anyone explain this Reed anomaly to me, and could anyone possibly clear the blurred picture up for me?
gman007
West Michigan
Razor
I believe this subject has come up here before. Apparently during switch over to R models, there was a short transition period where some of the R models were build using the older parts in stock. So what you saw was probably a transition R model (at least that is my recollection of how this was explained previously)
chrisnazzy
Arizona
Just got a drop shipment from Rustoleum that I ordered from HD. Hammered Light Blue. 20180425_103927.jpg
