Can this tool be home made?
plinker
Northern Wi
I've made similar guide pins by cutting off grade 8 bolt heads and slotting them with a cut off wheel, they were 3/4-16 though and didnt need to be pretty. Someone with a mill could make them easily I'd think.
Rlfd213
Yeah those are easy. I think this tool falls under the there is a sucker born every day.
WWheeler
Middleofnowhere USA
If you have easy access to that size bolt and threads then yeah, but I'd much rather be the 'sucker' that paid $30 for the set delivered than have to run down to Fastenal (30 miles one-way) which is the closest place to me that might carry that bolt, then have to cut the heads off and grind a slot.
Then again, if I knew the right bolt/threads I could just as well order a couple bolts just the same. How much would I save would determine which I chose. Usually I'll pay a little extra for the time-saving option though.
ocloc24
Screw using a mill all you need is an angle grinder or a dremel
Sent from my SM-N950U using Tapatalk
454ragtop
Carver, MA
Kind of surprised the SO ones aren't made with a little taper on the slotted end for easier component alignment.
ddawg16
S. California
I've made the same 'tool'. Takes all of 5 minutes....1 minute to cut off the head and make the slot, 4 min to go grab a beer.
seanb02
The Farm
Have several different sizes of those floating around the shop. With the bolt selection I keep stocked it is easy enough to grab one and make one as needed.
Schurkey
I've got a half-dozen pairs of alignment dowels like that, in assorted diameters and thread pitches. Each one lovingly crafted from SAE or Metric bolts, heads cut off and slots carved with a hacksaw or die grinder. Yes, I put a taper on them to ease alignment.
I use a pair every time I put a manual transmission onto an engine. Most recently, Isuzu Rodeo.
plinker
Northern Wi
What is the purpose of the slots; just so you can turn them with a screwdriver?
More or less.
With what I've done, I would thread them in finger tight and if necessary to remove them, loosen with a screwdriver or drag link socket.
Moose Legs
Edmonton AB
In my shop and service truck we have plenty of handmade dowels like that, but we also plenty of spare bolts those sizes and the tools to cut them so it’s convenient to just make them ourselves. If you’re in a situation where it’s inconvenient I can see someone just spending the $30.
Mr_B
Reading
it common metric size/thread, just need long shoulder bolts to hack up, you got cut threads so no protruding threads then cut unthreaded shoulder to required length and slot end.
With spare junk bolt selection or any local hardware store and equipped with an angle grinder it a quick tool make and make decent and cost anything from 0 to 5bucks diy . They sell the guides T10406 for 9bucks in europe .
larry_g
oregon
Lets state this another way, I didn't know those could be store bought...And I have quite a few of them.
lg
no neat sig line
