Milwaukee Drill Difference
D45
NW INDIANA
I am looking at some Milwaukee cordless drills, what is the difference:
2704-20
2703-20
2702-20
2606-20
2607-20
D
D45
NW INDIANA
2607-20 is a motor with brushes and isn't listed as "hammer drill/driver"
This is listed as compact drill/driver
500 in-lbs of torque and up to 1,800 RPM
An all-metal gear case and 1/2" metal chuck
Milwaukee® 4-Pole Frameless Motor
LED light
0-400/ 0-1,800 RPM
3 pounds
D
D45
NW INDIANA
2606-20
This is listed as a compact drill/driver
Milwaukee® 4-Pole frameless motor
LED light
0-400/ 0-1,800 RPM
2.9 pounds
D
D45
NW INDIANA
SO can I assume that the 2606 and 2607 drills are not brushless and are 2 speeds?
I am looking for a drill to match my Milwaukee 2750-20 impact, which has Redlink and Brushless features
D
D45
NW INDIANA
2704-20
M18 FUEL™ 1/2" Hammer Drill/Driver
POWERSTATE™ Brushless Motor
1,200 in-lbs of torque and up to 2,000 RPM
Redlink
No Load RPM 0-550/0-2,000
BPM 32,000
7.75” in length
3.5 pounds
D
D45
NW INDIANA
2703-20
M18 FUEL™ 1/2" Drill/Driver
Redlink
BPM ?????
7.50” in length
3.14 pounds
D
D45
NW INDIANA
2702-20
M18™ 1/2" Compact Brushless Hammer Drill/Driver
Milwaukee® built brushless motor
Redlink
500 in-lbs. of torque
No load RPM 0-450/0-1,800 RPM
7-3/8" in length
3.0 pounds
woody 73
The Great State Up North
D45 Hi,
I am a little confused by your question, perhaps if you started telling us what it is you are looking for in a drill?
Do you want a heavy duty power for larger jobs? Do you want a drill that is lightweight and will not give your arms a workout ? Are you looking for something that holds a charge for a longer time? A drill that can take on concrete 24/7 ? Something that will be only used for drilling in steel ? Something that you only want to use from time to time etc.?
LXCam
I don't know the part numbers off the top of my head but I can tell you this. I bought my first M18 tools in 2011. The typical full kit with the 1/2" combo 2 spd hammer drill. I just recently bought a new fuel to replace that one as somebody who shall remain nameless let the smoke out of it. Just last weekend I have several (3/16 pilot) 1/2" holes to drill in 1/2" steel and all though it performed incredible, I'm not totally sold on if it warrants the price of admission over even the original stuff. But granted I haven't really paid attention to battery usage or anything other then just flat out ability to perform a task....your results may vary ;)
D
D45
NW INDIANA
I am looking for a new cordless drill...........homeowner use for various projects
I want it to match my Milwaukee 1/4 impact 18V platform, so I don't have to buy another charger or another battery
I have a corded hammer drill that I will break out, when and if I need the hammer drill power
D
D45
NW INDIANA
2704-20
2703-20
2702-20
2606-20
2607-20
It seems like I won't be happy with the 2600 series
The 2702 seems to be the oldest of the 2700 line
The 2703 and 2704 are nearly identical
The 2703 is $129.00 and the 2704 is $149.00
2703-20:
https://www.milwaukeetool.com/Products/Power-Tools/Drilling/Drill-Drivers/2703-20
https://www.homedepot.com/p/Milwauk...2-in-Drill-Driver-Tool-Only-2703-20/206320079
2704-20:
https://www.milwaukeetool.com/Products/Power-Tools/Drilling/Hammer-Drills/2704-20
https://www.homedepot.com/p/Milwauk...mmer-Drill-Driver-Tool-Only-2704-20/206320081
I think the 2703 is not a hammer drill
D
D45
NW INDIANA
The 2703 only has 2 settings: drill and driver
The 2704 has 3 settings: the 2 mentioned above and a third of a hammer. This allows you to drill into brick, concrete, masonry, etc., properly with a vibration or hammering effect.
DonkeyFluffer
The 2704-20 FUEL 1/2" hammer drill is probably your best bet. It is frequently "matched" with the 2753-20 FUEL 1/4" impact driver in Milwaukee kits. The 2703-20 is fine, but adding the hammer function for only $20 more seems to make sense. I choose FUEL anytime that a FUEL version is available, though the others are fine DIY tools too.
Any M18 battery will fit any M18 tool., so it's really hard to get it wrong.
DerekV
Central TX
I guess, if you like sloppier chucks and slightly longer/heavier tools, totally worth the $20 [emoji19]
The 2703 is an amazing drill. I save any stone-like drilling for the SDS. Hammer drills are a JOKE!
NotOrganized
If you want a brushless, focus on the Fuel line. If it does not say Fuel, it likely has brushes.
DonkeyFluffer
For occasional use, the hammer function of the 2704-20 works fine. I've driven over 40 tapcons with it. True, it's no SDS, but many here can't justify buying one of those for the once-in-a-while use.
