Hopefully someone here can give me a a little insite on how to get this hub off so I can replace the axle seal.
I have a cubcadet z-force zero turn mower and need to remove the rear transaxle hub so I can replace the seal that is leaking. The transaxle is a hydro gear zt-2800. The hub is splines as well as a press fit to a tapered axle shaft. I tried using heat as well as a two jaw puller with no luck of removing the hub after many attempts and pulling from different areas until I pulled off the flanges and managed to break a flange with one of the wheel studs completely off. So now not only do I need to replace a wheel seal, I need to replace the hub.
Anyone have any tips to get this hub off?
