LimitedReality
After almost a year of going back and forth with my township over where and how I could build, we've finally gotten started on my garage build. The only problem is, now that we have the block foundation in, I am starting to wonder if the mason passed on quoting the driveway wall and instead suggested I could do it myself because of the logistics of it. Maybe I'm over thinking it so I'm looking for advice.
The only place that I was allowed to build is on a fairly decent slope (see drawing below). This causes the drive coming up to the garage door to need to be built up about 5" on the right side and 2.5' on the left. From researching online this kind of low retaining wall would normally be either:
The challenge with either of these ideas is I had to squeeze the drive in between two mature trees that we really don't want to take down (we bought the place for the beautiful trees). So I can't dig down so close to the trees as I'd take out their root system.
I'm wondering if anyone has done a similar retaining wall without a footer? Without digging down? I may be able to drive rebar safely into the ground every other block to pin it in place, but I worry about the longevity of that rusting out and giving way. Again from reading it seems like there won't be a ton of outward pressure on the drive since the majority of the load will be in the center. I plan to keep my motorcycles on the outside edges and a truck in the center.
Thoughts?
- Dug down one block deeper than ground level and using interlocking retaining wall block to stack up from there.
- Be dug below the frost line and built on a proper footer like the foundation.
Thoughts?
