I am NOT a code expert, but a retired security consultant who often dealt with fire code matters when designing security systems. Before you purchase a wired glass lite ( window ) for any door, or for a lite ( window ) adjacent to a door, research it carefully. The firm I worked for did a fair amount of work in K-12 and higher education buildings, and back then, there was a prohibition against using wired glass in those locations. I do not know if that applies to residential use, but suggest that you investigate prior to installing wired glass. The problem is that, when broken, wired glass has the potential for very severe injuries.
The code changes on a 3-year cycle, and not all jurisdictions are up to date, in fact most are a version, or two, behind the current one. In any event, you must comply with whichever version your AHJ says is the one to follow.
