Welding table casters
Youngfd
Maltby, WA
I have a HD welding table that I will be moving from storage to my shop. It is 36 inches wide by 72 inches long, 36 inches tall with a 1 inch solid steel top. It weighs in 1200 pounds. Looking to put it on 5 inch or 6 inch casters. Should I put 4 swivel casters or 2 fixed and 2 swivel? Either way with wheel locks. Also I see casters with ratings anywhere from 350 pounds per caster to 1100 pounds per caster. How heavy should I go? Thanks, j
up a creek
Thunder Valley
^^^^^ Yes sir as heavy as you can get within your budget. You never know when you might have a huge load on the table. Also, if it were mine, I would get 4 swivel with all being able to lock down. Much easier to maneuver that table with or without a load on it.
Tennessee Cattleman
East Tennessee
I would go with 2 fixed, 2 swivel, that will give the table more stability without having to lock the casters and swivels every time you use it. Caster load rating depends on the intended load, with a large 1200 lb. table, i wouldn't go with less than a 500 lb. rating per caster.
Kev In
Lethbridge, Alberta, Canada
I have a welding table with four swivel casters, if I did it over I would have 2 fixed and two swivels. The 4 swivels are more difficult to steer.
Go with at least 500 lb wheels
tarmy
Nor Cal
Don’t buy cheapo casters, they flatspot. Get big enough diameter to easily roll over expansion joints and cracks. These are ER Wagner...or get RWM47...
rpcraft
Waco
Also do not buy cast steel wheels, like the crappy stuff HF includes on all their things. Nothing like being stuck on a grain of sand on your nice smooth concrete floor because of crappy material. The units tarmy are showing look like good quality items, plus they will be a little more easy on the ears when you are moving the table around.
6PTsocket
It is a trade off. Two fixed steers better. Four swivels can be pushed into places that two fixed cannot go, like between two other things. I would go with two fixed, as well.
FTG-05
TN
I put Surplus Center 6" 550 lb or 600 lb castors on my 500 lb welding table over 20 years ago or so. It's worked well other than the fact that I very rarely move it.
Tennessee Cattleman
East Tennessee
Hamilton casters with Duralast wheels should work well, just don't cut metal toward them with a torch. Hamilton makes some of the better casters today, shop around, they aren't cheap. By using 2 fixed and 2 swivel casters, you should be able to get by on wheel locks on just the 2 swivel castors and not need swivel lock pins at all for a welding table.
tarbellb
Oregon
I have a 1200# wedding table with 4 swivel, it's manageable, but 2 fixed 2 swivel is better if you have space.
My casters are 6" full locking, meaning both wheel and swivel lock for a pretty stable platform. It will budge a bit tho. Get casters rated for at least 50% the total weight, it's never perfectly balanced on all corners.
A urthane w metal center is best, other compounds like rubber and poly will work.
Look at RWM, Albion, ERWagner, Shepherd? In 5"+.
Rory Bellows
Buy off ebay. I would also buy a floorlock. I got one off amazon for $35.00 but haven't installed it yet. With a floorlock you wont need locking casters. I would get steel or cast wheels. My Lista cabinet has 5" wheels and it rolls easily packed to the gills.
