Band Saw Project
Ridge, New York
Picked up this band saw a few weeks ago for a good price. Thought youz might like it.
I don't plan on restoring it, just going to set it up for metal cutting and fine tune it to work properly. I plan to add a giant old 110v motor, and an under-drive gear box. Then I'll try to use a light dimmer switch from the hardware store as my VFD so I can control the FPM.
Other than that I will stock up on blades and fabricate / repurpose a rudimentary safety guard.
I only have so much space in the garage but I definitely have a footprint for this relic.
Stuart in MN
Minneapolis
The dimmer switch won't work - they are designed to reduce the voltage to a light bulb. You need to reduce the frequency to a motor.
OccupantRJ
Eastern North Carolina
If you gear it to get 200 feet per minute blade travel, you won't need variable speed. I ran a vertical saw for 28 years cutting metal at that speed.
