Acetylene vs tig torch
TomC750
Upstate NY and TN
Is a tig torch an acceptable substitute for an acetylene outfit, considering that I will have a plasma cutter? Say I want to heat up a piece of stock to bend it or heat up a frozen nut. Considering selling my bulky old acetylene set rather than move them as I'm moving 700 miles. Thanks in advance for the collective experience of this great board!
alexb2000
Fort Worth, TX
Depends on what set you have. I wouldn't give up my Victor Journeyman 2 stage O/A setups for anything. There is nothing better for loosing up rusty bolts, cutting thick steel, heating something to bend, etc. I have watched guys beating on old bushings for hours and then used the torch to remove it in less than a minute. Even if you don't use it everyday, there are times when nothing else will do.
bdbecker
Iowa
Keep the regulator/torch and sell your tanks. Easier to move that 700 miles than the whole rig. When you get to the new spot, don't buy new tanks right away and see if you miss having it. If you don't, sell the rest of it.
sberry
Brethren, Michigan
I have an anxiety attack if I get too far from a torch,,, kind of like a security blanket. As was said above, at times its the only thing and the difference between minutes and hours. Had some brake parts on a neighbors truck the other day, no other good way to do it.
matt_i
SE Michigan
I would investigate the cost of getting "newer" tanks in your new location first before putting them up for sale.
PNWguy
Near Grants Pass, OR
Unless you're moving everything in a small car, I don't see how they would take up that much room in the moving van/truck.
I just moved my torches (3 different sizes, plus multiple tips and accessories), regulators and bottles 400 miles. I don't use them often, but the replacement cost on nice older Victor gear would be too many dollars.
Dragfluid
Pillager, MN
Keep both. I can't imagine not having O/A. Get some of that wrapping cellophane and wrap up the whole works and it will keep it solid. Take the regs off of the tanks and put on the caps, of course.
Fueler
Urbana, IL
Do you actually own the tanks or are the leased like most?
If leased, problem solved. Take your cart, hoses and gauges.
T
TomC750
Upstate NY and TN
Thanks for all the responses. I guess I will keep them. I do own the tanks and transporting them is not really a problem as I own the tractor trailer we are using to move with. As previously stated, box up the hoses and regulators, cap the tanks and secure them.
Milton Shaw
Your last post answered what I was going to comment on. Moving companies won't move tanks so you have to carry them in your own trailer. Make sure you have the proper warnings on your trailer for all the gas/chemicals you have on it in case you are stopped and inspected... Have a safe move, I agree keep your tanks...
rlitman
Long Island
2 tanks do not add up to enough to require placarding. They will however be enough to prevent you from driving through some tunnels around here.
Orangestang
Glendale ,AZ
Like someone else said sell the tanks keep the gear. When I moved I had everything packed in a Uhaul, ox/ac tanks,propane and welding tanks, I didn't read all the fine print till after I moved but your on the hook for the truck if there's a fire our something.
sberry
Brethren, Michigan
Agree, out of sight out of mind. I am the same sentiment, will say it again, a torch is part of every good survival kit. It really is and keep the tanks full. Its something that if it is used on occasion is worth looking for another O2 tank especially with buying used. We used to have to pay thru the noise for them. I would get a propane tip too. Can always cut with it and serves as backup supply from a 20# bottle.
I have a big heavy service truck. I use stick weld and a torch on it. No feeder, no plasma. It can be a highly accurate tool with a good finish with some practice and instruction. As simple as it is the more you do the easier, I can tell from lack of practice that its not as smooth as it can be. This is irrelevant for most things.
The last set in the pics I bought at a local sale. I give about 150, the bottles were about full, the torch head was good and used 1 of the regulators. A bottle was 250 from the dealer plus fill. I wanted another set of spares, I fill them when prices are stable and given the little I use them anymore can go a long time between having to fill and having full in stock.
Never need to have an inconvenient time to need gas you don't have, can change a tank at midnight if needed.
T
TomC750
Upstate NY and TN
More perspective! Some of the responses triggered an old memory of a motorcycle mechanic I knew. He worked on a lot of oddball bikes and always had his torch within arms reach as he sat on a stool. Without a moments hesitation he would grab the torch and modify a wrench as needed in order to fit that difficult to reach bolt.
Thanks guys, I am all set.
