It might be a good idea to lay 1 course of concrete block along the perimeter where no doors are planned, to help get your framing wood higher than the ground, plus if you are in termite country, give yourself a vertical break where you can see if they are actively trying to attack your house.
what is above the porch, do you have a photo of the porch related to the rest of the house?
No insulation above porch.Is the roof of the porch insulated?
My buddy owns an A/C company and told me it would not be difficult to split a duct to run a/c to the new area.How would you condition the new "office"?
During heavy rain, water tends to puddle due to the splashing of nearby rocks/pavers. I would like to take as much precaution as possible to keep water from getting in.Have you ever had any flooding issues on the porch?
Do these pics help answer this question?How much lower is the porch than the interior of the house?
Thanks for all the advice! Here are some more pics from above the porch...always connect framing members to other framing members (all that trim should come off so you can verify the structure underneath is without rot/decay).
what type of concrete block? like pavers?
I was thinking more like the 8x8x16 hollow core "CMU" blocks that you butter with mortar, set vertical rebar pins, perimeter bar along the top by chipping the webs, and then anchor bolts for the bottom plate.
As far as your question converting windows into doors, there does exist a header but I don't think its wide enough. So it becomes a project of building an auxiliary structure to hold the roof up (typically temporary stud wall or an internal or external flat-header like an LVL or a 2x10/12 that's screwed to every stud on the surface) while you remove and widen the existing opening and replace the header. Size for the door unit you will put in, flash, etc. The most tedious part might be repairing the stucco back and then probably a repaint of the entire wall to make the repair blend. Its a bigger job and not one that typically impresses the ladies in your life with the great outdoors staring them right in the face, with no mitigation, at times during the process....not to mention the dust + dirt generated.
I do not see anything in the "enclosure of the porch" that would require the work/expertise/cost of hiring a contractor.
adding outlets and/or modifying electrical circuits - yeah.. call an electrician
adding bathroom or otherwise modifying the flow of waste out of the house - yeah.. call a plumber
just a thought here, but why not rip sleepers to install so that the addition and the existing home are at the same elevation? Notching the bottom of them every 16" will allow for cross ventilation and I'd vent the edge at the bottom along both sides of the new exterior wall.How is he going to ensure no water intrusion in the new room? Is the soffit vented in that part of the roof? Hvac requires a feed line and a return line, how is he going to plumb the return?
Those are just points my not yet coffee fueled brain can come up with this morning.
Not a bad idea but there's also no insulation under that pad and you didn't mention it either. That means that room will be cold in the winter, though I forget where the op is located.
There's a lot that goes into making a porch into a 4 seasons space. I've seen it done wrong more times than not, and it always leads to problems down the road. For instance, the kitchen I redid where I had to shim the cabinets up 2 3/8" so the floor of the porch could be floated to be level with the rest of the house.
