We moved into our new-to-us garageless house about a year ago. We are about ready to start with the garage build but we have a bit of a situation. I was hoping someone here may have some experience with wells.
Here is the best photo I could find of the culprit:
When we were looking at the house, my thought was, "what idiot put a planter in the driveway? We'll have to take that out." It turns out I should have said, "what idiot drilled the well in the middle of the driveway?" Once we pulled back some of that English Ivy planted in the middle of it, we discovered one of these:
My question is, is it possible to dig down around it, "chop off the top," and surround/cover it with something similar to this:
We are looking to build the garage in the grassy area to the left of the house as you are looking at it in the photo. That will put the well right in front of the garage doors. Worst case, we can try to align it so the well is centered between the two doors and just reduce the size of the circle of block around the well. But I would like to bury it down if it is economically feasible.
I know it isn't ideal to bury them. My thought of doing it with a structure like that is that it will still be "above ground" within the structure and wouldn't have the issue of getting ground water or whatever down into it because it would have the space around it supported by the structure. It would also leave plenty of room around it for service, if necessary.
