Snap On Magnetic Driver SSDM40 Cap Solution
straightcut
Phoenix, Arizona
There are many of the discontinued Snap On magnetic drivers (SSDM40) in the wild that are relegated to the bottom of the toolbox because they're missing the NLA end cap. I like the black hard handles, but need the cap so I don't loose the bits.
Step one: determine the thread size needed for a cap: M18 X 1.5
Step two: find something suitable for a cap
-My google-fu came up with a thread insert made by Time Sert. The only problem was that I didn't realize they size them by their internal thread size.:lol_hitti Of course, we're looking for the external thread to be M18 X 1.5. A call to Time Sert's tech support got me the correct part number - Insert #51401. The length of this insert is 9.4mm, which works well - not too long or too short. The insert is copper plated steel.
Step three: find something suitable to JB Weld into the insert. I found a 3/8 drive/gear left over from a Snap On F936 ratchet rebuild. It's low profile, serrated for grip and it keeps things in the SO family for the fan boy in you.:pimpflash
The insert can be ordered from Amazon. It's not the cheapest solution, but does get the tool back in action. Post up your cap ideas if you've got something clever.
wkndwarrior29
NorthEast
That is a creative solution.
I probably would have just filled it with Bondo (because I have some old Bondo around) and smoothed off the end then painted it to match. Or just left it open.
I didn't realize losing these caps was a problem, mine all seat pretty tightly.
Sent from my XT1650 using Tapatalk
seber
Deep East Tx.
Why wouldn't you just cut off an 18 x 1.5 hex cap screw. You could even grind the cap down to look nice.
Snaparxon
Eastor
I tried that. The weight of the bolt head made the screwdriver feel awkward in my hand. I just didn't balance well.
6PTsocket
I found the almost perfect plug. They call it a blanking plug. It is made of gray nylon, has a thin head with a screw slot in the top that looks like a coin would work fine. They are being sold by somebody on the Walmart site. They are $5.93 for 20 pieces. The thread length is 8 mm. They are hollow from the under side so should weigh almost nothing. It says "clearance" so if you want them you better move on it. The thread pitch is not in the description but is clearly visible on the plug, in one of the pictures, M18 x 1.5
davethorik
Norka, Ohio
My Williams WRS-1 And Snap-on TMR4 both have the o-ring cap and knock on wood, never had a problem with them coming off.
That being said I admire your ingenuity. Definitely a more steampunk solution than oem. I'd rock it. :thumbup:
straightcut
Phoenix, Arizona
Thanks for the great tip! Despite that I'm set, I couldn't help but to purchase this. It might be better than what I made!
Qualitytools
SOCAL
I have my cap but it was cross-threaded and ruined the screwdriver threads. I had to use pliers and gouged the cap to remove it. I think what I need is a thread chaser the clean up the screw driver and cap.
any suggestions?
Qualitytools
SOCAL
I tried an M18 X 1.5 bolt, but it was too heavy.
I like the idea of the O2 sensor plug - that's a great idea!:bowdown:
See if a driver will exchange for a new one.
I have had that screwdriver since the late 90s and I no longer have access to a driver. However, I do see a truck on the road every now and then maybe I can carry it with me when I am out and about. Thanks!
alinc100
Dearborn,MI
I can confirm the 18mm x 8mm blanking cap works. Sits a bit proud on the end,but I'd bet some filing,or even a small gasket or o-ring solves that problem ,for sure now it will hold bits. I ordered mine (after a google search) from NewEgg Blanking Cap ,I've got 19 left ,LOL
