Bench Grinder losing power.
Zombifyd925
Saratoga County, NY
Hello all. I purchased a used bench grinder last year and finally got around to rehabbing the garage into a work space. I tested it out and it loses power with any decent amount of pressure applied to the wheel. And if anyone knows anything about it, that could be helpful too.
Thanks
exmaxima1
Midwest
I live in Geneva IL and never heard of that maker. I suspect it is one of those shaded pole type motors with very little torque. Really only usable for sharpening a screwdriver or kitchen knife, albeit very slowly.
notlob
norcal
HP = V*A*EFF/746
Even if it runs at 90% efficiency (which is unlikely), that motor makes:
115 V*1.9 A*.90 EFF/746 = .26 HP
So that is a 1/4 hp grinder, which, as stated above, is not powerful enough for anything other than the lightest of uses. IME, you need at least a 1/2 HP grinder for serious use, and 3/4 or 1 hp is even better.
Twystd1
The OC
That will barely grind a nail. The smallest grinder I have is 3/4 HP.
All the lesser ones are too inadequate for forcing work onto the wheels. Be it buffing or grinding.
And yea. I like getting things done fast. :)
-T
6PTsocket
My old 1/3 hp Craftsman "block" grinder runs fine and have no reccolection of stalling it out. I also don't try and force feed it. I prefer my belt sander for most jobs so I don't use the grinder that much.
exmaxima1
Midwest
HP = V*A*EFF/746
Shaded pole motors are rarely more than 20% efficient. That grinder has barely enough power to keep itself spinning. For example, a typical 1/4hp shaded pole grinder of that era draws 7.5 amps.
tool_scrounge
Southern California
HP = V*A*EFF/746
You forgot the power factor since it is an a.c. power device. For a resistor is is 1, but for an inductive motor it is less.
