MJK
Hi All,
I've been reading up on this for a few weeks now and I feel like I am swimming in options.
I have a 15 year old house with a 840sqft garage. A few years ago my wife got me the gift of an 'epoxy' floor while I was out of town. It was a very nice thought, although I suspect the handyman she hired went to Home Depot and tried to get a 2.5 car rustoleum kit to cover it. 3/4 Ton truck has worn through parts, fluid spills ate through some, tires leave gray tracks, etc.
My OCD can't take it any more and I am in the process of removing it. Joints are cleaned out. The rest will be diamond ground, degreased, etched and then... ???
I want a smooth, durable garage I can easily clean and I want my expansion joints gone. Pressure wash, squeegee and done.
Option 1 - Porcelain tile seems a good option, but expensive. If I did this, I would be using a lighter tan/gray/taupe tile and slightly darker grout. How big of an issue is it going to be to keep grout clean? A floor steamer seems to work just fine elsewhere in our house with 3 dogs, a pool, kids, etc.
Option 2 - Sand/Epoxy filler the cracks, grind and put a 2 part epoxy over it. I don't want any yellowing or fading near the doors, so I have thought about adding UV to the epoxy coat itself and skipping the clear.
Option 3 - Polyurea. It seems new and marketed as more durable? Can you seal the expansion joints before coating as you would with epoxy? How about UV resistance.
Moisture/freeze considerations are not applicable here in AZ. But dust , dirt, and heavy daily use are.
Thanks for any advice from those who have been here/done that. I have ZERO desire to repeat this in another 3 years so durability is more important than price, and I am much more likely to go with something 'tried and true' rather than take a chance on the latest greatest thing.
Any option would likely be DIY'ed unless someone has personal experience with a 'floor whisperer' in Tucson, AZ.
Thanks in advance for any wisdom you can share.
Best Regards,
Mark
Best Regards,
Mark
