frame it out and drywall. Anything else will look silly against the fridge.
to that ^^^^^^^^^
I vote sheetrock. Make sure you have clearance for your fridge door.Built out a stud track this morning. Now i gotta figure out what to put on it, filler panel or sheetrock. Sounds like most people are saying sheetrock it.
Tthornto: you say “a wider filler panel would look out of place.” What if I cut the filler panel to the same depth as the cabinets (Not including the doors)? So the panel would be flush with the front box of the cabinet. I can’t order any more cabinets. - Production time and budget constrained.
Dragrcr890: Option 3 sounds interesting. Are you saying slap the filler panel against the side of the fridge? Then build a sheetrock wall. In terms of the reveal b/w the right fridge panel and the sheetrock, are you suggesting the fridge panel should be slightly exposed (side view)?
Thanks for the help guys.
Yeah there’s a good 14 1/2” of protrusion from the wall to the door of the fridge.
I still don’t get why people are recommending sheetrock over filler panel to cover up the ugliness.
Sorry for jumping the gun earlier. Since it is that weird 45/135 degree angle, I would say take out the framing and put in built-in shelving from floor to ceiling. For continuity, you could frame and sheetrock the top to match the rest of the kitchen. You can put the one wall 2-3 inches from the fridge. Choose whether you want the shelf to be open and appear to be 45 degrees when approaching from the side for smaller items or make the shelves face the same side as the fridge and as wide as you like along that short wall. If you have power on that wall, you could even install some lighting like in a curio cabinet.
dragrcr890; said:now seeing your framing, I would sheetrock the metal studs all around, and just add a filler from the cabinet above the fridge over to the wall, leave the right side of the fridge alone and have a few inches to the metal framing, you don't need it that tight. now you need to decide where to stop your crown.
