Boosted1
Nice job on the sway bar links.
I am also interested in the repair kit brand.
I have a chip that needs repair too.
Well done Mike. What brand repair kit is that your using, I know you mentioned it before but I don't remember.
Nice work!
I'm curious, what are the 2 antennas on the bike for? I assume FM radio, and ????
Just came across this and wanted to say it's an awesome thread!
Mike, the Model A flywheel job you did with the gap bed removed got me thinking (ok got me wanting a bigger lathe like your's lol). However, I'm guessing that the flywheel diameter where you removed the material still fell within the range of your cross slide/tool-post right which even on a 13x lathe is something like 6.5" or so - in other words 13" diameter limit right?
Cool thanks!
Hey Mike I have an RV question. Do you raise the tag when backing up? Someone on one of the boards mentioned that he always did that to reduce stress on the tag linkage. Hadn't heard that before so thought I'd ask an expert.
Too bad you don't live closer, I'd love to come by and check out the shop.
Now you have one more area to polish off water spots when you clean it. Ooohhh, shiny!Now you have one more area to polish off water spots when you clean it.
Nice work Mike!
Whoever gets that coach after your tired of it will have one fine ride. WOW!!
Nice work around Mike. So can I assume that the trampoline effect is now gone?
Mike, would it make sense to add a thin rubber mat material between the screw jack and the coach floor and shower tray? (two places) I was just thinking it might help isolate it and help keep it in place. I have no idea how much the coach flexes when traveling on the road.
Nice attention to detail.
5200 can hold the world together![]()
The bushing at the shifter was starting to deteriorate and crumble.
Why do you suppose it’s so hammered? That should have lasted quite some time even if that Jeep sees 4x4 frequently.
Unfortunately the OEM is most probably using the wrong resin for the bushing application. The combination of heat/cold and exposure to hydrocarbons crazes and deteriorates the resin. I'm quite sure there are better resins out there for the application but it probably came down to the bean counters saving pennies.
I could probably turn up a bushing out of Ultem or a glass filled Nylon that would outlast the current bushing by orders of magnitude.
YMMV
zmotorsports said:I don't know what it is about these plastic bushings and keepers on these JK's. I wonder if it is the heat as the cat is right near the area. This particular Jeep does not see a lot of offroad so not a lot of activity on the shifter and cable.
The Advance Adapter's transfer case shifter cable upgrade was one of the first mods I did to my Jeep when I purchased it back in 2011 I was so nervous of it happening. Now I shift with confidence...
