I may have to check out those SS couplers. They look pretty nice.
Husky has a safety coupler knockoff for less than $5/ea.
I'm just sayin' you can replace them 3X for what the cost of a single Prevost coupler..
That only helps with fittings to hose/tools...the problem is generally the coupler itself.Do you use plumber's tape? I use that and it doesn't leak for me.
Milton M-style although the forum has its V-style converts.
I am a happy v style convert.
Milton V style high flow couplers and plugs is what i use. never had a issus.
I have Milton V female couplers. They seem to work fine. The high flow does make a difference. I also like that they will still accept an M style or non-high flow connector.
The male ends are a mix of Milton V and HF.
A couple local tire shops use couplers with a blue plastic jacket. I swore they were Kobalt, but I haven't been able to find them at Lowes.
Just changed all mine to Milton V's. Noticed a difference for sure.
Can the prevost coupler be used with milton V plugs?
I have tried a couple different kinds of couplers and have had no luck with them not leaking. Anybody have any suggestions on a brand that has a good fit and no leak?
FYI, you brought back a pretty old thread.
But yes, I use and like those:
https://www.homedepot.com/p/Husky-1-4-in-Female-Safety-Coupler-HA2001/205064344
They're aluminum, so they are pretty light weight. And the rubber cover makes it less likely to ding something painted it may run into.
