Fretters
Steel', you only need to drill the tip of the pin if it's flared/mushroomed. Just deep enough to remove the centre from the flared portion, so that the wall of the pin can readily collapse as you tap it through. I normally use a dulled centre punch placed into the divot left by the drill tip to start punching something through, when using that method.
Even though mine took around twenty years to receive a freshen up, she was stripped, cleaned & lubed straight off. Tools should be looked after if reliability & longevity are desired.
Wouldn't dream of having a frequent use vice unbolted. Accidents have a bad habit of happening, without actively encouraging them.
Except of the P98 none of my daily users have been cleaned, disassembled or even greased. And like KMScott, not one of them is bolted down. I'm like the car mechanic with the broken down car.
