Offset machinery casters
Bellaireroad
Fort Worth
Please share your pics of machinery dollies you have made with offset casters...in other words the caster sits outside the frame, and the frame rides low. Looking for ideas, thanks
Ole Slewfoot
Freedom, CA
Radial arm saw base I found today
kbs2244
I don't like them.
I am always kicking them.
In the back of my mind, the cabinet corner goes to the floor.
lilredex
Toronto
Here are some on my mobiles. I like three wheelers and pivot beams.....
930dreamer
Amarillo,TX and Stinnett,TX
I'd like to make something for this blast cabinet and remove the pallet its on. The frame casters would be inboard.
2oolhound
BC Canada
Here's a popular bike lift that uses the low profile design:
OccupantRJ
Eastern North Carolina
For most stuff like that I just weld up an angle steel frame and tack weld the casters right to it. Then set the cabinet down inside the frame. I allow 1/4" total clearance. My blast cabinet and filter bag house were separate until I combined them into a dolly frame to make a unit out of them so it could be moved easier.
clubairth
I love my blast box mounted on caster!! Even added a vac bracket hanging off the side. Super easy to clean up and get it out of the way.
I try to put everything I can on casters.
Oregon rock crusher
West of Salem
Here's a few I've added to machines...sometimes you just don't want to have to work with the added height of under casters and if you splay them out the corners they add stability when moving. I haven't had any problem tripping on them. Ed.
Oregon rock crusher
West of Salem
A few more....some were just temporary to get machines moved to their new home. Ed.
fnieto
Tucson,Arizona
I been using this design for many years as I like to keep the machines as close to the floor as possible.
Handy on the plate roller for a one man shop.
This mill actually belongs to a friend. My precision machines are not on caters.
Not used as much now since I can drive the fork lift in the newer shop, but when I was in my Garage, this iron worker (3500#) could be moved around.
These where the prefabbed brackets used on both the mill and roller (same design/dimensions).
The cold saw, band saw and finishing machine also share the same bolt-on design.
hope this helps.
Paco
Lelandwelds
Central Texas
Fnieto,
The similiar construction and repeating color make those sorta pretty. I could admire them up close when I am flat on my face from tripping over the damn things!
I am curious. Do you move a single piece out into the clear to use and put it back when done? Are you constantly juggling the different toys looking for the perfect shop layout? Are you moving the entire group of tools with the current long term anticipated need to the prime spot?
I make changes but slowly sneak up on "perfect". I like to move stuff with a pallet jack. I rest legs on the floor but plan cross braces to make it easier. Some stuff has a shelf to catch a couple timbers laid over the jack. Actually, I mean former shops. Might build the new one differently.
Your place is gorgeous. I am jealous. I could never keep mine so clean.
fnieto
Tucson,Arizona
Never tripped over them, I reconfigure the shop space for production runs and such. Like I mentioned, I use to operate in my garage for 14 years (1300 sf) so yeah having to move machines around was a must. These days most machines live where they are with the exception of the finish machine, profile roller, benders and plate roller. I park three rigs in the 3200sf space so some machines do require to be mobile.
As far as clean, well that takes effort too. Housekeeping is paramount to me.
sanddan
Oregon
I built this a couple of years ago. A HF 44" tool box with work surface. It now has a vise and aluminum trim to the top.
tarbellb
Oregon
fnieto- always expecting good work from you, nicely done.
I really like that bolt-on design, some nay sayers will complain about holes in the machine. But those who use machines know that its a minor point.
Bellaireroad
Fort Worth
hope this helps.
Paco
Awesome, how did you bend that 1/4 plate?
lilredex
Toronto
I gotta ask . . . What is a pivot beam? How is it different from a walking beam?
The walking beams I have seen have been on trucks and trailers and the action is parallel to the travel, they "walk" through the rough territory.
On mine, the action is perpendicular to the travel and do not really walk out of anything, just pivot to keep the machine stable. Stable, like those small restaurant pedestal tables that you wish would stop rocking and spilling your coffee, due to insufficient contact with the floor.
A couple more examples shown below. The only problem I have had with that setup was on the saw. With the motor mounted, it tended to rise up because of the imbalance, thus the concrete block ballast in the front RH corner.
cbacres
SW Florida
hope this helps.
Paco
Some really nice brackets there Paco. Is that a Ellis band saw? I have a smaller version, really a great little saw.
cbacres
SW Florida
Some really great ideas here. This comes at a great time as I'm close to adding casters to a platform lift and a genset.
I'll be getting rid of the store bought bases and will fab up custom ones like I see here, really improves the look.
Lelandwelds
Central Texas
I did it this way.
Slick execution. Nice job on the paint match. Do you have other receivers for the vice? You actually move it? Does just any extension cord power your outlets on the table or is it something dedicated and custom?
Is this a one off? Is your whole shop like this?
Lelandwelds
Central Texas
So, same thing just one is offset 90°? I sort of follow but don't see much advantage for the effort. Usually, I can find more examples when I google. Wouldn't three wheels accomplish pretty much the same?
Lelandwelds
Central Texas
fnieto,
I spent most of an hour thumbing through some of your posts and your one year build update. You seem to be one of those guys that everyone needs to stop talking and listen when you walk into a room. I am impressed by the most random things!
Fiber, rebar and mesh sounds fine to me. Darn even and shadow free lighting. Continuing the accent stripe is just excessive! Lol.
I encourage everyone to read your build thread. https://www.garagejournal.com/forum/showthread.php?t=259062
I hope you find retirement to be everything you hoped. Please post more photos. Any subject is fine with me.
fnieto
Tucson,Arizona
Those bent brackets are 3/8"x4" CR. Used the iron worker with the break press tooling to break the flat bar.
cbacress, yes, that band saw is an Ellis 1800. I really like that saw.
Johnny_V
Mentor, Ohio USA
Mine is nothing fancy, but it makes storing and retrieving my lathe chucks and drive plates much easier.
BFBOB
I know I'm not the only clumsy one on this site - maybe the most clumsy, but not the only.
Sharp square corners are a no-no in my shop!
old-air-performance
Belgium
dirt_dobber
Bee Cave, TX
I have the Laguna 14 -12 Bandsaw and love using it - but it comes with a 3 wheel system and always felt like it was going to topple over.
I got this - Bora Portamate PM-3500-Industrial Strength Universal Rolling Mobile Base
They make several different versions but I really like the 3500 as it
will support 1500-lb. (680 kg) weight capacity.
Adjusts from 20.75 x 23.75 inches to 28 x 33.5 inches (53x60 cm to 71x85 cm)
Very low profile — increases machine height by less than 1 inch (2.54 cm)
very heavy duty and great fit and finish.
I brought this on Amazon for about $140
The 3550 has all 4 wheels swivel but is closer to $200.
