Raisedonadeere
Back around 2006 I installed successfully some 3 ton heat pump split systems. Just helping out some folks that were going to have to do without if some one did not extend charity. Those systems are still running no leaks. I used Mapp gas to braze the line . The new Mapp gas concerns me that it won’t do the job.
The expense of a acetelyn rig add greatly to my cost since I don’t anticipate needing it for anything else. Is there any other viable alternative torch setup for a diy install. I just learned about the oxy mapp torches but they seem to be high temp but low heat capacity. I just don’t know much except general theory about actual success on refrigerant lines these days. I do the nitrogen purge as I braze. I seem to recall that there are different things to watch for on R410 than my previous R22 installs.
But basically I just want a suitable torch for about 1/2 hour and be done with it forever.
