JZeeker007
So i have a 60gal sanborn air compressor with a 3.7hp pump. I am on my second pump as I thought the 1st pump was going bad. But the second pump is doing the same thing, but wasnt right away. When it kicks in and starts up it sounds like a dying turkey, chirps and gobbles for about 45-60 seconds and then is smooths out and runs and pumps just fine. Any thought? Oil is full and clean. Belt seems to be tight. I cannot tell if its the pump semi seized and needs to loosen up or the motor just not spinning it up right. But every time it will smooth out and sound normal. Any help or ideas would be greatly appreciated. Thank you in advance!
