HotRodHudson
- Joined
- Nov 18, 2013
- Messages
- 373
I need some skilled advice here guys. I’ve become familiar with using Kroil & similar penetrating products and even had some success with applying heat with my little hand held propane torch but what to do when things fail, I’m at a loss.
For example, I have the exhaust manifold off of the 37 coupe and unfortunately in the process of removal broke the two studs in the manifold which attach to the intake manifold. Never wanting to admit defeat & wanting to do it all myself I tried lots of Kroil again over a few days then drilled the broken off studs with left handed drill bits. I was hopeful that as I went larger with each bit it might just break it free & spin out with the use of the left handed bits vs right handed bits. Unfortunately that didn’t work.
Through this I ended up drilling almost to the beginning of the threads and that’s where I stopped. Not having a large set of drill bits I couldn’t go larger without destroying the threads in the manifold. A buddy advised me to take it to a machine shop so I dropped it off there tonight even though I wanted to figure out how to finish doing this on my own. Now I’m having some regrets as it will cost $75 just to have the shop finish getting the drilled (3) studs out. Naturally I was thinking of the additional tools I could buy for $75 especially if I can buy what I need to do the rest of this myself. Plus I’m sure it won’t be the last broken stud I have. So I really need some wisdom & advice on how I could still possibly finish getting the studs out. I hope that makes sense?
