Would You? 10hp Compressor 3 Phase
u3b3rg33k
If considering a VFD, you may wish to check with the manufacturer and make sure a reduced speed does not affect lubrication as well.
per the link above it's splash lubricated, but if it's capable of being run slower with a 5hp or 7.5hp motor, then using a VFD to slow it down to half capacity would be no different.
Strouty
Southern Maine
It looks like it could be pressure lubricated from the picture, so until he posts the entire Model number, I can't be sure. Using a VFD to slow it down is a sure way to burn out the motor and spend a lot of money on a VFD for no reason. Just figure out how much air you need or want, then either buy a 5 hp or 7.5 hp setup.
u3b3rg33k
or he could re-pulley it so cooling isn't an issue (as previously suggested), and have a 5 - 10 hp compressor depending on his needs. but sure, buying a motor for each task is an option, too. potato tomato.
7635tools
Southeast Wisconsin
Can you even run a 10HP motor on a residential service? Forget about the dedicated circuit ampacity. Just the crazy power draw of a reciprocating piston compressor with that much motor behind it is going to cause power issues for your neighbors.
My 7.5HP single phase compressor does everything I could ask of it. My guess is that this one can be repowered with a smaller motor. Perhaps with a smaller pulley to match.
I run a 40hp phase converter off my residential service with no problems.
tarbellb
Oregon
Good find, they are becoming more popular for sure.
I considered $1000 a lot for a VFD upgrade in my situation.
Also, there arent many benefits to a "variable capacity compressor"? It needs to start, stop, and repeat reliably, opposed to a sander where slowing it down has benefits.
For $1000 you can find a excellent USA 5hp motor, mag switch, belts, pulleys, etc.. and have money left over.
cvairwerks
Within hearing distance of Texas Motor Speedway
American Locomotive
Rhode Island
...and also have half the air flow.
u3b3rg33k
Sure there are
slower = quieter
less amp draw
possibly a cooler running compressor
longer run time (can be good if you're trying to avoid cycling it on and off).
He'd have to check the motor data plate first. That drive is limited to 33 amps, and some 10 hp motors run way more than that. You also need to note that the drive requires a dedicated 80 amp feed too.
I would hope anyone seriously considering spending that much money would investigate thoroughly, or at least state their intentions before buying it. I'd only throw in so much effort at this point considering OP may flip it for a profit.
He speaks the truth. if you need more air than a good 5HP compressor will supply, the best 5HP compressor in the world still isn't good enough.
Bert_
NW Iowa
Sure there are, you can match pump speed to your demand. Reduces wear on the pump and motor without all those starts and stops. Maybe not as important in a home shop but that can be a big deal in industry.
I think there is a member on here that has a vfd on his compressor set up with multiple stages to match the usage.
