Femi 782xl Band Saw
Bigblue&Goldie
I've been wanting a better way to cut tubing at home, so I finally broke down and bought a new saw. I weighed all of my options, and ultimately decided on a mitering head band saw. I love band saws because they are quiet, make clean cuts, and make a minimal mess........everything an abrasive saw fails miserably at.
I've seen various Taiwanese saws, but I was leary over parts availability down the road, so I went with the Italian Stallion Femi 782xl. It wasn't cheap at $500 delivered, but these days quality costs money. I settled on this particular model as I don't need a power down feed and the biggest tubing I will likely cut is 3" square, with most being 1.5" or less round tubing. I won't break down the spec's, but here they are if you're interested: http://www.femi.it/en/femi-machine-professional-processing-wood-metal.aspx?l=51&f=28&p=127
Out of the box you have to cut a bunch of zip ties and remove a small amount of packaging. You then attach the handle using a 2mm allen key. I quickly went over it to make sure everything was tight, and all appeared proper. I plugged it in, grabbed a piece of 1" .120 HREW tubing and gave it a whack. I didn't expect it to cut straight without adjustment, but to my surprise it was dead on!
Pros:
- Quiet
- Accurate out of the gate
- Minimal mess
- Head miters up to 45°
- $25 blades that should last hundreds of cuts.
- Large capacity (4.125" depending on material)
- Vise is far better than any chop saw I've used
- Portable, weighs about the same as a chop saw
Cons:
- Price when compared to saws performing the same function
- Blades are a ******* size, but readily available online (not locally that I'm aware of)
- Handle is plastic, but should hold up if not abused.
- Included material length stop (not pictured) is plastic, but should also hold up if not abused.
In summary, this thing is badass and I wish I would've bought one much sooner. I can't speak for longevity, but initial impressions are positive.
Bigblue&Goldie
2nd cut (1st was to cut off existing end of tubing). Note this is about the thickness of the blade.
lis2323
What's it like with "manual" cut? I'm so used to horizontal bandsaws with auto ( hydraulic and counter weighted ) operation.
I'd be concerned with too much, too little or inconsistent downfeed. Nice looking unit though[emoji106]
The Cobbler
Bigblue&Goldie
Not bad at all, you can feel the blade doing the work. The last horizontal Jet I used with power down feed was so picky that half the time I'd keep a hand on it while cutting thick material (bar stock).
BD1
north side
The Ellis is cool, but I don't have room for it right now in my garage.
That saw has great reviews you have. I did buy their ELLIS 1600 because of a super deal. It does has have a large footprint.
Your saw is basically the same with smaller capacity and 1/6 TH the price.
There both better than a hacksaw.
Ellis recommends break-in for new blade. Just saying in case you're not aware.
Slow 1/3 down pressure rate for 10 minutes of cutting.
lis2323
An Ellis has always been on my wish list. Recently I was surprised to find one (albeit beat) advertised locally. I’d never even seen one in my area before.
I bought it for less money than I would have paid for taxes and shipping on a brand new one. [emoji106]
Here it sits today with new stand, paint decals, in and outfeed roller tables etc. I have a few more things to do but still have my old saw to use. (Being retired is NOT overrated ). [emoji3]
bullnerd
Jersey
Thanks for the review.
I'm up in the air right now between that saw and the Fein Slugger 14.
I need one, but still cant decide.
I like band saws too, for the same reasons you mentioned.
Bigblue&Goldie
My reasons for not going with the Slugger or similar was the expensive blades, noise (I work when the kids are sleeping), and mess. I don't want hot *** metal chips covering everything in my garage. My kids and wife walk through the garage, so I have to keep it decent.
bullnerd
Jersey
I agree.
Post a pic when you miter some square tube if you get a chance.
RivennHewn
PNW
I love my Femi.
Be careful with the plastic handles. I've replaced two already. You don't need to crank them super tight.
Read and understand the blade/material/speed part of the manual.
I found it hard to get used to a saw that weighs a lot less than the material it's cutting, but it does it soooo nicely!
zkling
Those are the ticket for most home machine shops and fabricators. I'm surprised Milwaukee can't piece one together for around the same price. Battery powered even.
Bigblue&Goldie
I have a Milwaukee portaband mounted in a Swag table and it's an awesome tool as well.......no Doall, but great for knocking out small parts.
tarmy
Nor Cal
Love mine too...I will post some photos for a new portable cabinet I built for it...
Bigblue&Goldie
I agree.
I haven't mitered any square tubing, but I did cut some 2.5" .250 wall square tubing the other day. It took a while, but it cut through it cleanly. If you are in a hurry, these saws aren't nearly as fast as an abrasive, but the cut quality isn't even comparable.
bullnerd
Jersey
I ordered one! lol!
Should be here next week.
It was a toss up between this and the Fein slugger, I went the quiet route this time.
GRB
SoCal
We had a Hemsaw H90A that was very impressive. When Hemsaw took on distribution of Femi in the US, we sort of giggled. THEN, we saw just what they could do. Very impressive saws!
bullnerd
Jersey
Got mine today.
Being a machinist for almost 30 yrs, your used to seeing quality stuff.
So far I'm not super impressed with the tool.
One of the small levers for the blade guard is stripped right out of the box.(someone mentioned to watch the plastic?)
The directions for blade tension are vague to non existent. (not a big deal)
Foam from packaging went inside the vent slots on the motor.
Screw for the vise is intermittent tight/loose as it travels.
Sliding the saw through the angle settings is intermittent rough/catchy, not smooth.
I'll give it a chance.
Bigblue&Goldie
Got mine today.
There are definitely some cheaper aspects to it, but compared to what $500 gets you in another saw I think it's worth the price. I watched some review videos of the Slugger (and similar) that were less than favorable, especially with regards to the vise. The levers being plastic was a surprise, luckily they can be had in metal fairly cheap. I also felt the tension instructions were lacking, but I've always considered bandsaw blade tensioning a "feel" thing.
2.5", .250 chromoly solid stock:
From the supply house:
JordonMusser
Dallas, TX
Nice man! I have been thinking about something like this. I wish it had an add on table for vertical use (I use a SWAG /dewalt setup right now)
bullnerd
Jersey
It Does.
I would imagine you'd have to clamp/bolt it down though, it feels like it would tip easy when in the upright position.
tarmy
Nor Cal
It Does.
Mine is not...they have a very heavy base...and are very stabil...might be an issue for long stock though...
sqznby
Coastal NC
How do you like it? I considered that one, but the size was too much for my garage right now.
So far I'm pretty impressed with it. The adjustable feed rate is very nice as is the swivel head. I've cut a bunch of stainless tubing and some mild steel and am pretty happy with it so far.
I'm also lacking in the space department, this is crammed in my 10'x16' shed:wtf: But, the longest length I cut are 4' so it works out well. If I do have to cut something longer its not so bad to roll it around or I'll cut the stick shorter to fit inside or hang it out the door, hah.
Here's a cut from some 1.5" .065 stainless tubing. Not too bad.
WagonHo!
Albuquerque, New Mexico
How about some update reviews on the Femi 782xl band saws. Any comments on durability issues or features? How about the add on vertical cutting table?
Someone picked up a grizzly band saw anything to add now that you’ve used it more
Bigblue&Goldie
So far so good, but I had the same plastic handle strip out. I haven't got around to warrantying it yet.
I can't comment on the table as I have no experience with it. I have a Milwaukee portaband in a SWAG table and I like it a lot. Throat depth is an issue, but I have gotten tons of use out of it over the years.
cspcrx
Phoenix, AZ
I am very happy with my still and impressed with the cut quality it provides. I am getting ready to build my work bench this winter and it will get a workout then. Right now I have just used it for a few projects nothing really intense.
I have used the table once, it was very handy. once you set it up and adjust the leg it pretty much drops in and is ready to go.
WagonHo!
Is it the tension adjust knob that stripped out? I talked to a sales tech at Trick that owns one and he had the same plastic problem knobs but the USA - HEM dealer took care of it. He loves the accuracy and no lube, no mess, small footprint and no hernia lifting. Thanks
WagonHo!
Appreciate the response. No reservations as far as cut capacity or plastic knobs?
