Pipe Extractors
mooman
CHICAGO, IL
I'm planning on changing a leaking plastic drain valve on my water heater with a brass one.
I've heard that these usually break off inside the tank during removal. Sooooo, I'm looking for a decent 3/4" pipe extractor. Anybody have any good ones?
Tool Pants
San Jose CA
My plumber friend loaned me a giant easy out. There is another style that expands inside the pipe.
He has helped me replace water heaters at 2 different houses over the years. He does not like the plastic drain valves. He removes them and puts in a threaded brass ******. Then screw on a ball valve. Then on the end of the ball valve a pipe thread to garden hose adapter is screwed in. You can then hook up a garden hose to the water heater.
He likes the ball valve because you can get full flow if you need to drain the tank, or to remove sediment at the bottom of the tank. If the valve gets clogged with sediment while you are draining it you can stick a screwdriver down the ball valve to clear it, which you can't do with a normal type of valve.
Mickey O
Chicago, IL
Internal pipe wrenches, you can get them at any plumbing supply house, maybe even Ace Hardware, Blowes or Home Depot.
Thedroid
New Mexico
I have a set of generals, I don't think they are USA though. Quality is ok. On plastic I think the big easy out would work better. The extractors are kind of picky about the id of the pipe. They are made to fit a certain size, and if its not a perfect match they tend to slip pretty easy.
basspro
In the sticks, WI
All you need is a square chunk of aluminum, a hammer, and a channellocks. I use em all the time. Slam the aluminum in the broken piece, them giver a turn.
nick__m
I've got a set Proto internal pipe wrenches that are a different style than most others but I haven't had a chance to use them a lot. They don't seem to be widely available, but they show up on ebay frequently.
